Introduction: How to Turn Resistors Into Earrings
It is a well-documented fact that everyone loves resistors. Even cats
But when they have been foraging for them what can you do
with them?
Turn them into Jewellery.
Step 1: Ingredients
1. Some resistors.
2. (Optionally) Shrink wrap and something to shrink it with.
3. Earring wires – you can get these from any good craft shop.
4. Sandpaper
5. Round or Needle nosed pliers
Step 2: Join the Bits Together
Thread a small section of shrink wrap onto the resistor then form a loop with your pliers
Slide the shrink wrap up to cover the joint and shrink it (you can use a match for this) Shrink wrap is available in a variety of colours, but I only had black. You can skip this if you don’t have any.
Step 3: Finish Off
The other end you can form into a spiral by wrapping it round something or just cut the end off in which case you probably need to smooth it off on some fine sandpaper. I have put a loop in the ear end as well.
Step 4: Refinements
As a further refinement get old bit of cable, take the insulation off and use it to cover it up the wire. Of course you dont have to stick with earrings - you can turn them into bracelets or necklaces by linking many together.
