Introduction: How to Unlock a Protected PDF File
Sometimes, you may want to read some PDF eBooks away from computer. Cause it’s not a good experience to view on screen for a long time with endless scrolling over the pages. Fortunately, you can print them out from any PDF reader then read at hand easily. But there is confusion about how to print protected PDF files.
Actually the author of some PDFs removed the print or other actions’ permissions from users before publication. In that case, the file for you is read-only and even more restricted to an electronic way. But don’t be frustrated and directly assume that we can do nothing next. This article is all about tips and tricks to unlock a protected PDF file.
Firstly, let’s check the precise PDF security of your file to see if you have to unlock PDF documents. Open your file in Adobe reader. Then you will see an obvious symbol of a secured file is a padlock tab which on the upper left. On the navigation, click File> Security> display, then you will know it clearly.
If you lucky enough you can get a workaround rather than a must to unlock a protected PDF document.
For example, if you are allowed to duplicate, you can copy and paste into other redactors and then further reuse will be an ease. Or if there are just a few pages, you can use a screenshot program to capture the content so as to print from images files. But sometimes “copy with the help of tools” can be disabled.
Whatever you cases are, a Powerful PDF Password Remover is a solid solution for you to unlock PDF documents without extra efforts.
With it, everything becomes simple to unlock locked PDF files. I mean, you just collect all the protected PDFs and add to it. Then it will remove permission passwords from them and present you unrestricted documents in a while. All the files of you will display as original but free to access.
A step by step tutorial for people who have already completed installation to refer to:
First step: Launch the PDF Password Remover and then you will get an intuitive user interface.
Import the protected files by clicking “Add Files” button to browse through local discs.
For the user password/open password secured files, you need to enter the password so that it will make opened files for you.
Last step: Customize an output folder in your PC for all new opened files as per you need. After all these has been done, finally click “Start” to begin the process to unlock encrypted PDF files. Soon you will get the unrestricted files.
Isn’t it super easy? More efficiently, as long as it has been installed, therefore you are able to unlock a protected PDF file by right-click feature and no need open the program. This is very convenient for you to unlock encrypted PDF right away when come across one.
After unlocking PDF documents, you can do as below:
Having got the unlocked files, you are capable of reusing them for copying, printing and editing in Acrobat suite or any other PDF editor.
Another alternative method to unlock PDF files:
It’s also a common and good way to convert PDF to editable word documents for PDF file modification. Find a PDF to Word Converter which will unlock PDF documents for conversion is a quite welcomed one stop solution.
