Introduction: How to Use 2.4inch TFT LCD SPFD5408 With Arduino MEGA 2560
This instructable will show you how to interface the SPFD5408 2.4 Inch lcd to the arduino MEGA
Step 1:
Step 2: Libraries
Some of you may have purchased this LCD Screen or thinking of getting
one. Its a great screen for displaying images and graphics. I purchased mine for displaying sensor data from my 10 sensors on my robot via xbee (telemetry). I bought it not only out of impulse as it was very cheap but also that it was the biggest screen i could find cheaply in Australia. ($15).
Enough of me rambling...
Unfortunately this LCD Screen has not much support and i have seen people unable to find libraries for it especially for the MEGA.
THIS IS FOR THE MEGA
1.I used the SWIFT Library and the Adafruit GFX Library
SWIFT Library by smoke and wires: https://github.com/Smoke-And-Wires/TFT-Shield-Exa...
Smoke and wires lcd tutorial http://www.smokeandwires.co.nz/blog/a-2-4-tft-tou...
2. Adafruit GFX Library
AdaFruit GFX Library https://github.com/adafruit/Adafruit-GFX-Library
Step 3: Modify the Libraries to Interface With MEGA
2.After copying the libraries over to your libraries folder, open the SWIFT folder, locate SWIFT.cpp and change this line from:
// Use the include which corresponds to your arduino
//#include "mega_24_shield.h" #include "uno_24_shield.h"
to this (just un-comment the mega part and comment the uno part.
#include "mega_24_shield.h" //#include "uno_24_shield.h"
This will allow you to use the screen on the arduino MEGA. In terms of
the connections from the screen to the mega, just plug it in like a shield the same way as you do when connecting it to the UNO.
Step 4: Display Text on the Lcd
// Code provided by Smoke And Wires
// http://www.smokeandwires.co.nz // This code has been taken from the Adafruit TFT Library and modified // by us for use with our TFT Shields / Modules // For original code / licensing please refer to // http://www.smokeandwires.co.nz
#include // Core graphics library #include "SWTFT.h" // Hardware-specific library
// The control pins for the LCD can be assigned to any digital or // analog pins...but we'll use the analog pins as this allows us to // double up the pins with the touch screen (see the TFT paint example). // #define LCD_CS A3 // Chip Select goes to Analog 3 // #define LCD_CD A2 // Command/Data goes to Analog 2 // #define LCD_WR A1 // LCD Write goes to Analog 1 // #define LCD_RD A0 // LCD Read goes to Analog 0
// #define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD: // For the Arduino Uno, Duemilanove, Diecimila, etc.: // D0 connects to digital pin 8 (Notice these are // D1 connects to digital pin 9 NOT in order!) // D2 connects to digital pin 2 // D3 connects to digital pin 3 // D4 connects to digital pin 4 // D5 connects to digital pin 5 // D6 connects to digital pin 6 // D7 connects to digital pin 7 // For the Arduino Mega, use digital pins 22 through 29 // (on the 2-row header at the end of the board).
// Assign human-readable names to some common 16-bit color values: #define BLACK 0x0000 #define BLUE 0x001F #define RED 0xF800 #define GREEN 0x07E0 #define CYAN 0x07FF #define MAGENTA 0xF81F #define YELLOW 0xFFE0 #define WHITE 0xFFFF
SWTFT tft; // If using the shield, all control and data lines are fixed, and // a simpler declaration can optionally be used: // SWTFT tft;
void setup(void) { tft.reset();
uint16_t identifier = tft.readID(); tft.begin(identifier); }
void loop(void) { for(uint8_t rotation=0; rotation=1; rotation++) { tft.setRotation(rotation); testText(); delay(20000); } }
unsigned long testFillScreen() { unsigned long start = micros(); tft.fillScreen(BLACK); tft.fillScreen(RED); tft.fillScreen(GREEN); tft.fillScreen(BLUE); tft.fillScreen(BLACK); return micros() - start; }
unsigned long testText() { tft.fillScreen(BLACK); unsigned long start = micros(); tft.setCursor(0, 0); tft.setTextColor(WHITE); tft.setTextSize(1); tft.println("Zhungu Robotics!");
tft.setTextColor(GREEN); tft.setTextSize(2); tft.println("Motor temp ~56 degrees C"); tft.setTextColor(WHITE);
tft.println("ESC Temp ~50 degrees C"); tft.setTextColor(MAGENTA);
tft.println("Methane Sensor ~20ppm"); tft.setTextColor(CYAN);
tft.println("Hydrogen sensor~0.2ppm"); tft.setTextColor(RED);
tft.println("Co2 Sensor ~70ppm"); tft.setTextColor(MAGENTA);
tft.println("Air pressure ~100011Pa"); tft.setTextColor(GREEN);
tft.println("Current temp ~30 degrees C"); tft.setTextColor(YELLOW);
tft.println("Current Humidity is 50%"); tft.setTextColor(CYAN);
tft.println("Altutude ~45m"); tft.setTextColor(WHITE);
tft.println("Voltage remaining ~ 7.6V"); tft.setTextColor(BLUE);
tft.println("Current draw ~12A"); tft.setTextColor(GREEN); tft.println("UV Index is 12mW/cm^2"); tft.setTextColor(RED); tft.println("light intensity is 930Lux");
12 Comments
4 years ago
It seems that the author did not test this code at all, or he left something out of the Instructable. The error with the incomplete #Include statement is solved by commenting out that line and adding the lines for the Adafruit GFX library. But then the compile fails in several ways.
1. The constants for the colors (RED, BLUE, etc) are not defined and in the statement "SWTFT tft;" (about line 20), SWIFT is missing a type declaration.
I haven't solved the last error and I may just move on using what limited knowledge I picked up from this Instructable.
Reply 3 years ago
Moving on would be best. There are better supported screens available at an attractive price point...regards
3 years ago
it is not gonna work please dont follow
Reply 3 years ago
This instructable worked well for me, i am not sure what you are doing wrong. As mentioned before in the instructable, this is not a well supported screen. At the time i purchased it ~5years ago it was the only one that size i could find, now there are more screens available that are better supported. I suggest using those. I also suggest reading up on whether a product is well supported or not before purchasing too avoid issues in implementation. I see no reason to buy this screen now, when there are many and better supported ones available to use?
5 years ago
Assistance please, all I get when trying to compile this is the following error:
Arduino: 1.8.2 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch_may06a:4: error: #include expects "FILENAME" or <FILENAME>
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Reply 4 years ago
i too
4 years ago
I have only a white screen at here, what am i do now? i had tried it with another pair of Mega and tft display, same result obtained
5 years ago
hi thanks for sharing code
i do it > but with inverted cordinates (mirror display )
can you help please ??
Reply 4 years ago
find this "void Adafruit_GFX::drawChar(int16_t x, int16_t y, unsigned char c,uint16_t color, uint16_t bg, uint8_t size)" in Adafruit_GFX.cpp
edit the for loop from this "for (int8_t j = 0; j<8; j++)"
to "for (int8_t j = 8; j>0; j--)"
7 years ago
so how do i do it if i have a arduino uno
Reply 5 years ago
I am afraid it may not work on Uno because of lower specs. but google up, with time people find out new ways
Reply 4 years ago
I hope you got the answer in time. This tutorial is meant for MEGA because it is quite difficult (more steps) to get it working. For UNO, there are generic codes and yes, it works beautifully
