Introduction: How to Use Adobe's IPhone Packager Without an Apple Developer Subscription
If you're like me, and just downloaded Flash CS5 to test out it's ability to create iPhone apps, only to be stopped by the fact that you have to spend money at apple to be a developer, then this instrucatable is for you.
This instructable will show you how to export a Flash iPhone project to an IPA without a Developer Connection with Apple, and then how to test that app on your iPhone.
Please note, you still will not be able to publish the apps that you create on Apples AppStore. (Well I don't know what would happen if you tried, but I don't see it turning out well).
Here's what you'll need:
- Flash CS5
- iPhone/iPod Touch
- The iPhone/iPod Touch needs to be jailbroken
- You need to be able to install IPAs by dragging them into iTunes or some other method
You'll need to look up instructions on the latter two if you're not sure on what those are.
To be honest I'm not 100% sure that your iPhone needs to be jailbroken before doing this. So if someone without a jailbroken iPhone wants to try this, by all means do and let me know how that works out.
Step 1: Design Your App in Flash
The first step is designing your test App in Flash CS5.
Once Flash is open go to the File menu and chose New...
And then in the New Document dialog, choose iPhone OS, and then click OK.
You should see a blank white box.
Using the Text tool on the right side of the screen, write some words in the box.
Step 2: Exporting the App
Before we export your App, be sure to save it (File>Save).
Now under the File menu, go to iPhone OS Settings...
and then switch to the deployment tab.
Download the zip file attached to this instructable and extract the files in it: Fake.zip and Fake.mobileprovision
Next to certificate, browse for FakeCert.p12 and select it.
In the password field enter 1234
Next to Provisioning File browse for Fake.mobileprovision and select it.
It should populate the App ID field automatically, don't mess with it.
If it doesn't it should read com.gamevil.zenonia2
Next click Publish.
Be patient, even on a fast computer, it may take a while for it to finish building the App.
Once finished, in the same directory as the fla file that you saved earlier should be an ipa file with the same name.
Step 3: Installing the App on to Your Device
Once you've found the IPA file, open iTunes.
Plug in your jailbroken iPod Touch or IPhone.
On the left of iTunes, select Applications. If you haven't downloaded Apps before on iTunes, you'll need to download an App from the iTunes AppStore, on your computer, before this menu option will show.
On the left menu in iTunes select your device.
Then on the tabs on the top click Applications. Make sure Sync Applications is checked. You should see your application in the list. Make sure the box next to it is checked as well.
Now press sync at the bottom of the screen.
Step 4: Test Out Your App!
After iTunes is done syncing, unlock your device, and find your new app!
84 Discussions
4 years ago
you can now upload apps with cydia impactor
5 years ago on Introduction
Please update this tutorial xD
Reply 4 years ago
why should he?
it still works
6 years ago on Step 2
the game downloaded on the phone but shows "Waiting..." when you try to open it...please help
thank you so much !!!!
7 years ago on Step 2
Hmm, i'm probably doing something wrong. I've made ipa file but when i'm trying to upload it to ipad with iFunbox i have error message: "Funbox involve the official app installation API on iDevice. All installed Apps work only within their own sandbox, which is safe and quarantined from the iOS kernel. To install unsigned/unofficial/modified ipa package, install AppSync from Cydia first."
Do i need jailbrake to upload this app on ipad?
Why i just cant install app Via USB
I got this to work with Adobe Flash Builder, but I did have to modify the Fake.mobileprovision file to have the same name as my project.
7 years ago on Step 3
does this certificate work with xcode?. thank you
9 years ago on Step 3
it says incompatible with my iphone. Please help
9 years ago on Step 2
Thanks for posting the files. When I try to apply the Fake.mobileprovision file to itunes, I get 0xE800801A error, which looks like an exchange server error. Can you please upload the files again?
Thanks!
9 years ago on Introduction
Hi bcarasco,
Thanks for the article. I have successfully followed until step 2.
However I am stuck at step 3, specifically in the last 2 paragraphs there:
"On the left menu in iTunes select your device.
Now press sync at the bottom of the screen."
How do I select my device in iTunes? and where can I find this Sync Applications?
Thx again.
Thanks!
10 years ago on Step 3
Thanks for the certificates but when i tried uploading it into my iPhone, an 0xE8008001 error came up....
Reply 9 years ago on Step 3
You need "AppSync for OS 4.0" to patch the mobile installation files and allow hacked ipa files. After jailbreaking, load Cydia and add "http://cydia.hackulo.us/" as a package source, then search for the AppSync application.
Reply 10 years ago on Step 3
I have the same issue. I'm gonna try jailbreaking my phone next. See apple, this is what happens..
Bingo. I had to install AppSync from Cydia, once that was done my app sync's just fine.
Thanks a million for this tutorial and files! This is great for getting your feet wet.
Genious! (:
When i try to sync the app to my ipod it says "the app"" was not installed on the ipod"" because it is not compatible with this ipod"
I have the same problem with my iPod touch and my iPhone 3G. One of them is jailbreak and the other one is not. I get the same error when I sync them with itunes.
Is there a problem with these keys or something changed in new itunes?!
Do the P12 and the mobie provision still work with latest IOS (4.3) and itunes(10.2.2). Is there some new restrictions?
I can't install my apps anymore..
