How to Use the Water Level Sensor - Arduino Tutorial
167,735
81
18
Introduction: How to Use the Water Level Sensor - Arduino Tutorial
About: Arduino Tutorials by Codebender.cc Team
In this tutorial you will learn how to use a water level sensor with the Arduino uno board.
This module is designed mainly for the DIY hobbyist and provide them a low-cost and easy-to-use water level detection scheme. The sensor that I will use for this tutorial can measure water level up to 40mm (4cm).
This is an analog sensor and the data that we will read will be values from 0 to 1024.
Let's get started and find out more about it.
Step 1: What You Will Need
For this project you will need:
  • Arduino uno
  • Breadboard
  • Water Level Sensor
Step 2: The Circuit
The connections are pretty easy!
  • Vcc - Arduino 5V
  • GND - Arduino GND
  • A0 - Arduino Analog pin 0
Step 3: Find Analog Values
We need to find analog values for our sensor.
Upload the following sketch on Arduino by pressing the "Run on Arduino" button and then press the "Connect" button to start serial communication.
Now take a glass of water and slowly put in it the sensor.
My analog values from this procedure are:
  • 0mm - 480
  • 5mm - 530
  • 10mm - 615
  • 15mm - 660
  • 20mm - 680
  • 25mm - 690
  • 30mm - 700
  • 35mm - 705
  • 40mm - 710
As you can see the sensor resolution decreases as the water reaches the maximum level.
On next step we will map those values to print on serial monitor the level of water on mm.
Step 4: The Code
Here's the code, embedded using codebender!
You can keep playing with that by clicking the "Edit" button and start making your own modifications to the code. For example try to change the delay time.
Step 5: Well Done!
You have successfully completed one more Arduino "How to" tutorial and you learned how to use the water level sensor.
I hope you liked this, let me know in the comments.
There will be more of them, so make sure to click Follow button!
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • Big and Small Contest
    18 Comments
    licheong
    licheong
    6 years ago
    Thanks! I'm trying to measure the water level on my balcony, but I wonder if there's any risk of short circuit if the water spills over the top. Is there any way to make the top part of the sensor water-proof?
    Waylon194
    Waylon194
    Reply 5 years ago
    I know this post is very old but I just wanted to give an answer.
    You have 2 options:
    1. Add heat shrink to the top of the sensor, this will prevent rain from getting on the board but it does NOT make it waterproof.
    2. Add hot glue/silicon sealing(I am not sure if you can use any type of sealent).
    ImperialR
    ImperialR
    Reply 2 years ago
    Or conformal coating is the best.
    SatyaD4
    SatyaD4
    3 years ago
    Hi Sir Good Afternoon i am trying to interface the water level sensor using Arduino nano for harvesting the fish Aquarium automatic water level detecting and filling the water below average of water but, the tank depth was 45CM the sensor size only the 5 cm how to apply the same application using long height sensor OR if any chance to increase the size of sensor please reply this question sir thank you
    link: http://bigbelectronics.in/product.php?product=rain-water-sensor-liquid-level-sensor-module-depth-of-detection-arduino
    ShankarB11
    ShankarB11
    3 years ago
    gusandfluffy
    gusandfluffy
    Question 3 years ago on Step 5
    Does anyone know if the temperature of the water can effect the functionality, or the accuracy of an arduino water sensor? Also, can the device be fully submerged and still remain functional? Thanks!
    Eldin96
    Eldin96
    Question 3 years ago on Step 3
    I have done everything same and on serial monitor the value is just decreasing until 374. Sensor is not in the water. What did i do wrong ? thank you
    GergelyO2
    GergelyO2
    5 years ago
    You can calculate exact mm values with the following code.
    A 4th degree polynomial fit approximates your calibration data with adj R-square over 0.99.
    The equation is:
    f(x) = p1*x^4 + p2*x^3 + p3*x^2 + p4*x + p5
    where x is normalized by mean 641.1 and std 83.32
    Coefficients (with 95% confidence bounds):
    p1 = 4.428 (1.955, 6.902)
    p2 = 16.17 (10.57, 21.76)
    p3 = 15.35 (12.44, 18.27)
    p4 = 7.229 (2.881, 11.58)
    p5 = 11.59 (9.973, 13.2)
    Different sensors need different coefficients or even different fit (cubic poly, exponential, power, etc.), but in your case these values are correct.
    CODE:
    const float p1 = 4.428;
    const float p2 = 16.17;
    const float p3 = 15.35;
    const float p4 = 7.229;
    const float p5 = 11.59;
    void setup() {
    Serial.begin(9600);
    void loop() {
    int a = analogRead(A0);
    float b = (a - 641.1)/83.3;
    float w = (p1*pow(b,4)+p2*pow(b,3)+p3*pow(b,2)+p4*b+p5);
    if (a <= 480){
    Serial.println("Water level: 0mm - Empty!");
    else if (a > 710){
    Serial.println("Water level: FULL");
    else {
    Serial.print("ADC: ");
    Serial.println(a);
    Serial.print("Water level: ");
    Serial.print(w);
    Serial.println(" mm");
    delay(5000);
    FermionN
    FermionN
    Reply 4 years ago
    Hi GergelyO2,
    Could you please provide the source of this information (the polynomial equation)
    Thanks in advance.
    acrtsh
    acrtsh
    Question 4 years ago
    hey, i'm using this sensor to my project, but anyone know kow much the accuracy value of this sensor?
    AdrianaE8
    AdrianaE8
    Hi... I'm using this kind of sensor to measure the water that is transfered from one small gobele to another, for a future project.
    1º Question: I like to know if your Arduino values for each "mm" of the sensor were always so accurate as you say in step 3. Becausa my values fluctuate a lot.
    2ºQuestion: I like to know if i can use de code that you put in the comments below to calculate the exact "mm" values
    Thank
    MaynardG
    MaynardG
    Question 5 years ago on Step 4
    Can I adapt this technique to indicate the water level in a 5,000 gallon water tank, 64" diameter, horizontal cylinder?
    rdemeter
    rdemeter
    5 years ago
    Hi! what exact sensor is this
    yussufbn
    yussufbn
    5 years ago
    pls i need ypur help on my project. which is "automated poultry feed and water supply" am using water level sensor and pressure load sensor
    Abu Bakar Saeed
    Abu Bakar Saeed
    Reply 5 years ago
    Where you are facing problem in your project
    Patrick_74
    Patrick_74
    6 years ago
    Can we use that sensor with gasoline, glow fuel nitromethane?
    Hooikraal
    Hooikraal
    6 years ago
    Thankyou, that helped.
