How to Use a Wet Tile Saw to Cut Glass Bottles
Intro: How to Use a Wet Tile Saw to Cut Glass Bottles
Please pardon the less than stellar photos in this Instructable.
It was created years ago when I had nothing but an inexpensive
digital camera. I hope to update it soon with much better images.
After purchasing numerous gadgets and widgets to cut glass
over the years, I finally discovered the joys of using a wet tile saw.
They are inexpensive, easy to operate and in my opinion, fun to use.
If you are in need of a straight cut on a glass bottle, especially
a wine bottle, this is right up your alley!
No wires, no candles or flame, no torches or shattered glass after
all that work.
As my intention for the cut glass is for a later project, if you seek only
to cut the top from a wine bottle to use as a glass, you'll find step #3 to
be what you need. Be sure to file, torch or otherwise smooth down the
sharp edges before using it as a drinking vessel.
Be sure to check out Fstedie's instructable for making drinking glasses out of wine bottles, too!
STEP 1: The Basics of a 7" Wet Tile Saw...
tutorial is basically aimed at cutting the tops off.
Hopefully, this Instructable will have you wishing and wanting a tile saw yourself.
Fear not, they are not as scary as you think, are very inexpensive, and may even be
in your garage already.
This tutorial is based on use of a 7" QEP wet tile saw. Many home improvement
stores offer wet tile saws; which are intended for use in cutting tiles for mosaic
and other projects such as backsplashes, counter tops, bathrooms, kitchens, etc.
It is an electrically operated saw which works with water.
While I have used a standard, inexpensive blade intended for tiles, there is a
blade available which is called a diamond blade. Let me reassure you that use of
the word 'blade' is not what it sounds like. In fact, it is nothing like an actual saw
blade with teeth or sharp edges, it is rough to the touch, though. Naturally one would
want to exercise caution with any power tool, so it is always a good idea to keep
your fingers away from the cutting wheel while in operation.
After familiarizing yourself with the initial operation of the saw itself, we'll
bring in the bottles, complete with pictures for each step.
For those who haven't any common sense, allow me to remind you of the
need to be of sound mind with all your senses in check before proceeding. In
other words, consumption of the bottle contents is fine, just not while doing this
project.
Put on some clothing you don't mind getting dirty and wet,
grab your safety glasses, ear plugs and let's have fun!
STEP 2: Choosing Your Bottles...
or odd shaped bottles are a little more difficult to cut straight.
Shown in this post are examples of different bottle shapes.
At left is a bottle shape typically used for Chardonnay and Pinot Noir.
Note the bottle shape allows for slightly over half the bottle
length to be cut into rings easily. Once you begin cutting into the
angled neck of the bottle, it is more difficult to keep the bottle flat
and straight, thus you must rely on your hands to hold the bottle straight
for cutting. Please note, you can use rings of all different shapes and
sizes.
The bottle in the middle is often bears Cabernet Sauvignon, Bordeaux
blends and such. The shape allows for more straight cutting and a taller
cylinder. The bottle on the right is almost a perfect choice, allowing you to cut rings
all the way to the top of the bottle, or to provide an even taller cylinder.
Think candle holders!
Remember this little bit of information when shopping for bottles,
especially at a recycling center. And speaking of recycling, don't feel
guilty at all about only getting a few rings out of a bottle. Keep a big tub
nearby to put all the scraps into, then be sure to take them to the recycling
center.
STEP 3: The Initial Cut...
Let's begin making those rings, shall we?
Make certain your saw is plugged in and on a stable, level work surface.
Ensure the water reservoir is full, make sure it stays that way every chance
you get. Babies, pets and other critters under feet are not a good idea while
using the saw. Don't look away while working. Instead, stop what you are
doing, turn off the saw, then tend to your business. Bottles can be replaced,
babies on the other hand...hmm. Not so easy.
Holding the bottle firmly, but not in a death-grip manner, slowly move the
bottle toward the blade. As you should have ear plugs in, you should still be
able to barely hear the glass hitting the cutting wheel. My personal manner
of holding the bottle is with both hands. My method is to roll the bottle towards
myself, rather than away, because I feel there is a greater chance of kickback
when rolling the bottle away from your body.
Speaking of hands, I feel much more comfortable using bare hands. Once in
a great while I will get a teeny tiny glass splinter, but as long as you work slowly
and carefully, glass splinters should not be that big of a problem, more of a
nuisance.
After you work, be sure to clean your hands and arms and put on lotion, as they
will feel as though you have been handling chalk all day.
Once the cutting wheel (or blade) has entered the bottle, slowly turn the bottle
back towards you, as though you were going to roll it off the table towards your
body. Slowly, don't move too fast. You will soon get the hang of it. Keep in mind
that thicker bottles will require more cutting time. Don't rush it. Let the tool do
the work.
When you have completed one ring, turn off the saw and examine it. See how
easy that was? If you didn't cut quite straight, don't worry, you can carefully file
it off using the saw or leave it as is, the kiln will likely melt away any imperfections.
STEP 4: The Hubs and the Nubs...(a.k.a. 'Punts')
as nubs or hubs on the bottom inside many bottles.
When you first begin cutting a bottle from the bottom, keep in mind
that you only need to cut through the glass enough to separate the rings,
or in this case, the bottom, from the bottle.
You might want to save these hubs, who knows when a new idea
may strike. Who knows, you may come up with a great thought for
using them.
STEP 5: Setting the Rip Guide for Straight Cuts...
of your cut. For those planning to make many rings, record the
placement of the rip guide with a permanent marker.
The rip guide is a bar which runs vertically across the saw table.
Most saws come with both inch and centimeter marks.
Slightly unscrew the knob, adjust each side of the rip guide, making
certain they are both the same, tighten knobs.
STEP 6: Keep Cutting Those Rings...
Now let's do it again. And again!
STEP 7: Finish Cutting the Bottle Into Rings...
the bottle which can be cut evenly, typically before the neck,
until the bottle is completely cut into rings.
Keep in mind, you don't have to work with the tiny section at
the top of the bottle. It is not wasteful to use another bottle as long
as you return the scraps to the nearest recycling center.
STEP 8: Details for the Techs...
(7" QEP Wet Tile Saw)
120 Volts
60 Cycle
3600 RPM
4 Amps
STEP 9: Now What?
Stay tuned, I'll soon be adding instructions for melting them in a kiln.
You'll have the coolest, tinkling, green chimes in town!
Karen Marie
86 Comments
magician176 4 years ago
StaceyR40 6 years ago
mferris4 8 years ago
I have a 4.5" tile saw, which should work, Just want a voice of experience from someone who has done it before. I know I will have to rotate the bottle. So far I have cut two bottles, but am not feeling I am doing it correctly. Lots of glass dust and a few chips. Can I do this with a 4.% inch blade?
WUVIE 8 years ago
Also, meant to say, if you use a diamond blade, the cuts will be much smoother. Shop around for the best price, and be sure to ask a lot of questions of the salesperson. Hopefully, they will be knowledgeable, and can help you select a good blade. :-)
metalman1949 6 years ago
I did not see anyone suggest filing the edges to smooth them.
It's easy to find affordable diamond files these days, Harbor Freight for example, or online. I have filed the edges of cut glass for years and it makes the edges nice and smooth, though no longer shiny. Does anyone know if polishing with a bench grinder and cloth wheel and jewelers rouge will shine and smooth even further the filed edges?
WUVIE 8 years ago
Hello! Nice to meet you.
First, I want to make absolutely certain that you are using a wet tile saw. When you use the term 'glass dust', I am concerned. You definitely do not want to breathe glass dust, or even tile dust, for that matter. If you are using a wet saw, make certain the reservoir is always full of clean water. Chips in the glass, well, that doesn't sound good, either. Make sure you are cutting slowly, and surely, and never forget that kickback could cause a serious accident in a hurry. Be very, very mindful and careful when cutting.
Yes, I also have a small saw, and while it will work, it will definitely take longer to cut bottles, but I turn them as I push them into the blade, securely and slowly.
Be very careful, and be sure to check back in to tell me (crossing fingers) that you are using a wet saw.
Wet saw. Glass dust on top after the water has drained back into the resevoir. Yes that was confusing. Wet saw, works best
lloweryan 6 years ago
I am so happy to see this, I have been collecting the bottles and dragging my feet on trying to cut manually.
Going to Home Depot this week to buy the Glass Tile Diamond Blade for the QEP Wet Saw. Thank you, Thank you.
DanielK343 7 years ago
Thanks so much for posting this. It was so easy! Tile saw cut through the bottle like it was butter!
NicC13 7 years ago
Hi will a 4 inch cutter work fine cutting the bottle ?
WUVIE 7 years ago
Short answer - yes, a 4" tile saw will work, but...
When you are cutting off the bottoms, it doesn't matter, as the glass will make contact with the blade. But if you are looking to cut off the top section, depending on the size of the bottle, you may not be able to reach it with the blade. Cutting it at a tilted angle is not my favorite thing to do, with regard to safety.
I hope that makes sense. If not, give me a poke, and I'll try to do a better job. ;-)
NicC13 7 years ago
Hi thanks for the quick reply it makes sense :) i think i will get a 7 inch cutter to give me the best versatility for diff bottles
TrystanO 8 years ago
hi there, has anyone used this method to slice the bottoms off cut glass decanters?
WendyH20 8 years ago
Hi,
Can you use this method to cut a bottle lengthwise - from neck to base?
Thanks
WineCraftG 8 years ago
Cathy
- WineCraft Glass
ChrissyA 8 years ago
WUVIE 8 years ago
Hi Chrissy, you may need to use a bit of wet sanding paper to smooth the edges, or it may be a blade issue. A diamond blade is best, but if you don't have one, just try to at least use a new blade, and work slowly, holding your glass to cut smoothly. :-)
Shera55555 8 years ago
Hi - Can you use a 10" Diamond Blade instead of the 7"?
We saw a youtube video where the woman just pushed the bottle through, we did this, but the cut ended up being all jagged. We will try your method of turning the bottle towards ourself through the blade.
Thanks!
SheRa
dranad 8 years ago
