Introduction: How to Use Resin to Make Your Own Plastic Stuff
Hi My friends
Actually i am an electronics designer but since childhood i was interest in both electronics and chemical and i wanna explain about one of my cool test in chemical to using this way as your needs
first , as you know if you wanna order a plastic melt for your testing design , it's not very economical because most of you are a hobbyist and don't wanna expend lot of money and at leat you must expend 500-600$ to order a plastic melt
but here i wanna introduce a very helpful and useful way to making your own plastic stuff's
This way is so so cheap and high quality (mostly depending on your skill) way to making lot of plastic thing's
So we are go to learn this cool way
Note: in this session we will learn how to make a liquid resin as plastic and you must make your melt as your needs
Dangers :
ALL of the material are chemical and please in all stages use safety eye gloss and gloves
please do not change the amount of the mixed material
please test this in balcony (with a fresh air)
Dangers :
Step 1: Essential Stuff's
from lest to right :
1: Resin
this liquid is one of derivatives of oil and is so so cheap , here is about 2$ per liter :)
note: we have several kind of resin such as epoxy etc. but as far as i know most of resin are good for our plan
2:Color
use special color for resin that be mixable with resin
3:Final drier , in last stage we mix this chemical liquid with our mixture to make hard our liquid and change liquid to solid
Note: actually this liquid in kind on acid and the color of this liquid is invisible
4:First drier or Cobalt : this liquid must mix before final drier
1: Resin
2:Color
Step 2: Pour Resin in a Box
i use a recyclable dish to make our mixture due to resin will make dirty your dish after drying
for the first test use only 100-200C
Step 3: Pour Color in Resin
pour your color in resin
Note: resin without adding color is primary colors (a little like yellow)
Step 4: Mix Color in Resin
you have to quite mix resin in all stage very strongly and does not contain any Impurities
Note: please Mix color in resin with a plastic recyclable knife
Step 5: Add First Drier
after adding first drier or acid into resin if you mixed very good , you must show a violet mixture
Note: with each 1000CC resin you must contain 100CC first drier
well , after this stage you have a violet mixture you can store this liquid for about 1 month and after this time will be not usable
Step 6: Adding Final Drier (cobalt)
This is the final stage to make a hard plastic and it's just enough to add cobalt to the mixture to make hard that
well i prepare other empty plastic box to test out plastic (it's like a plastic melt)
also you must mix 1000CC resin with 200CC cobalt
you can mix cobalt with mixture before or pour cobalt in empty box and then pour mixture in the melt
Step 7: After Drying
you can watch what we made by resin
Step 8: One Sample With Resin
This is a clamp that i made it with resin and right now i use this to assemble electronics boards
It were so useful in electronics boards
