How to Whittle a Grill/bonfire Fork
Intro: How to Whittle a Grill/bonfire Fork
This fork is an excellent camping accessory that you can make yourself with nothing more than a stick and a knife. It's great for bonfires and customizable.
If you liked this instructable, please be sure to leave a vote.
STEP 1: What You Will Need
- A stick (should be about 3/4 inch wide and can be as long as you want)
- Swiss army knife or other whittling tool
- Sandpaper (optional. I used some)
STEP 2: Mark the Handle With a V-groove
Choose how long to make the handle based on what is comfortable for you. Make a V-shaped groove that marks where your handle ends and the shaft begins. I made my handle slightly longer than what I could grip and it happened to be around the middle of the stick.
STEP 3: Flatten the Shaft Part of the Fork
Trim down the 'top' and 'bottom' so that the shaft is flattened slightly. Do this by holding the handle and carving away from yourself.
STEP 4: Curve the Sides of the Shaft
Cut down the sides and curve them slightly. It helps to leave the end intact so that you know you aren't cutting into the whole stick and only the middle part of the shaft.
STEP 5: Sharpen the Tip
sharpen the tip so that it is shaped like a flat-head screwdriver. Make sure you cut down the top and bottom, and not the sides.
STEP 6: Make the Prongs
Make the prongs by planning your cuts and then going all the way through with your blade. You can have three prongs if you want, but I prefer only two.
STEP 7: Sanding and Detailing
Detail your fork. Just make V-grooves and continue shaping the fork. Once the detailing is done, you can sand, if you like the 'rough' look, don't sand.
STEP 8: Roast Some Marshmallows!
Your fork is now finished. You can use it to roast different things like marshmallows and hotdogs. Carve the fork to fit your need, for example longer prongs for things that may slip off of smaller prongs.
Thanks for checking out my instructable. I hope you enjoyed it and be sure to vote for it in the contest(s) you think it should win. Comment any questions or recommendations.
Thanks again.
Thanks again.
3 Comments
VernJones 8 years ago
achávez17 8 years ago
