How to Wrap a Knife Handle With Paracord
Intro: How to Wrap a Knife Handle With Paracord
In this instructable I'll show you how to wrap a knife or tool handle with para-cord. I think that a plain old circular wrap is boring so I'm going to use a cobra weave instead. I am going to wrap the para- cord around a machete handle instead of a regular fixed blade knife.
STEP 1: Get Your Materials
Materials: Para-cord (about a foot of para-cord for every inch of the handle)
Any knife/tool with a handle ( we will only be wrapping the handle of the knife/tool)
Scissors
Lighter/ Matches
Scissors
Lighter/ Matches
STEP 2: Open Up Your Para-cord and Find the Middle
Open up the para-cord. Find the middle by holding the two ends in one hand and stretch the whole rope out. Then the opposite end of the two loose ends is the middle point of the para-cord.
STEP 3: Make the First Knot
Put the middle of the para-cord under the end of the handle closer to the blade. Once that is done, take the right side of the rope and make a loop over the handle as in the 2nd picture. Then take the left end and put it under the handle and bring it up into the loop. Pull it tight and then you have your first knot.
STEP 4: Continue the Knots
Use the left side to make the loop and make the knot all over again. Continue the pattern and keep switching the side that makes the loop.
Another way to find the side which needs to be the one making the loop is to find the bump that is made on either side and that is the side that needs to be making the loop.
STEP 5: Finishing Touches
If you have any slack left such as in the picture you should cut it using scissors. Then melt the ends using matches. Add any other things that you want to. For example I tied the ends in knots.
STEP 6: The Finished Product
Now you have a good grip on your knife or tool so it won't slip out of your hand when you are using it.
The picture is what my finished project looked like.
12 Comments
SamuelK37 8 years ago
Haha wow I'm actually from Belize.
TheNotoriousHoppington 8 years ago
It didn't last long. A few hours of heavy use at most. What am I doing wrong?
tranoxx 11 years ago
nitnit13 10 years ago
jbenfield1 11 years ago
sir-zeke 11 years ago
nitnit13 11 years ago
camping crazy 11 years ago
audreyobscura 11 years ago
