How To...build a Spudgun Ignition
Intro: How To...build a Spudgun Ignition
This is how i made my -sort of- remote controllable spudgun ignition
list of stuff to buy before you start on this project with a high awesomeness level:
piezo bbq-lighter
spark plug
wire
steel wire
tools: a wire stripper
tape ( yes , tape is a tool)
hands ( don't lose 'em , they might just come in handy)
piezo bbq-lighter
spark plug
wire
steel wire
STEP 1: Drilling
this is the part where you take out your drill , attach a drill bit the size of the threaded part of the spark plug.
Drill a hole in a strong , robust part of the combustion chamber
STEP 2: Wiring the Piezo Ignitor
Take the thing apart , but be careful not to damage the internal components.
you will see 2 wires , extend them by attaching a longer wire , and secure with electrical tape.
make sure everything is sturdy and tape it all up
(see picture)
then , tape one wire to the small pin at the end of the sparkplug , and one wire to the o-ring around the threaded part
(see picture)
STEP 3: Insert the Spark Plug and Secure
twist the wired sparkplug into it's place.
then take steel wire , turn it around the sparkplug , then turn it around the whole gun and twist the wire , so that it's stuck , once again , look at the picture
STEP 4: Testing
here are some pictures of the testing before and after putting it inside the gun
Btw , i'm from Belgium , so my English probably isn't perfect , so if there are any mistakes noticed by you , please alert me!!
11 Comments
DuhDuhDave 11 years ago
Great project.
crapflinger 14 years ago
wiebevandomburg.hotmail.com 14 years ago
indeed , 2 metal pins close together , it even has extra isolation and threaded wire , so you can jam it in there real tight , instead of hot-glueing your nails
jtorrez 12 years ago
RocketPenguin 14 years ago
Zaphod Beeblebrox 14 years ago
I tested it with a bigger endcap , but the gun was so powerful that it blew the cap off and rammed it into my stomach :P
it's pretty powerful , because , when i shot it against a 3 inch thick wooden board ( point blanc) it shot right trough :)
explosivemaker 14 years ago
pics or it didn't happen.....you would need a LOT of pressure to do that
also added a steel pin on top :P
that's why it shot trough
ps : the chamber is 50 cm long and the barrel 1meter long
