Introduction: How to Make Salsa
This instructable will explain how to make one of the easiest and most delicious salsas ever. It requires hardly any effort - no cooking, just chopping and mixing. If you make this right, you will never want to buy that lousy supermarket salsa again.
Step 1: Ingredients
All you need for this recipe is:
8 Tomatoes (I used Roma Tomatoes so adjust quantity based on what type of tomato you use)
Cilantro (Adjust quantity to taste, I used around 15 sprigs)
2 Jalepenos (Put more of the vein in if you want it spicier, less if you want it milder)
6 Garlic Cloves (Again, adjust to your tastes)
1/2 Onion
1/2 Cup of Olive Oil
Lime Juice (I ended up using the juice of 3 Key Limes, probably equivalent to 2 normal limes)
Salt to taste
You will also need:
A bowl or something to mix the ingredients
Something to mix the ingredients like a spoon
A knife
Again, you can adjust quantities to suit your tastes/yield.
And remember, the salsa will only be as good as your ingredients, so make sure to buy good produce.
1/2 Onion
Salt to taste
You will also need:
A knife
Step 2: Chop Up and Add Ingredients
Chop up the tomatoes, onion, garlic, jalapenos and cilantro and toss them in a large bowl.
Add the lime juice and olive oil. Hold on the salt for now
Step 3: Mix
Stir it all together, just don't mush it together though - gently mix it.
Step 4: Add Salt
Add salt to taste, I used a few pinches. Make sure to mix the salt in.
The reason why you should mix it before adding the salt is if you plan on using the salsa mostly for eating with chips, I would try it with a chip first. Some chips are saltier then others, so you may need to adjust the amount of salt you add.
Step 5: Enjoy
Enjoy your homemade salsa.
I like to keep mine in the fridge for a few hours before I eat it, since if you let it sit in the fridge for a while, the flavors combine together and I think it tastes much better. But if you are tempted, feel free to eat it right now.
