Humidity and Temperature Measurement Using HTS221 and Arduino Nano
Intro: Humidity and Temperature Measurement Using HTS221 and Arduino Nano
HTS221 is an ultra compact capacitive digital sensor for relative humidity and temperature. It includes a sensing element and a mixed signal application specific integrated circuit(ASIC) to provide the measurement information through digital serial interfaces. Integrated with so many features this is one of the most appropriate sensors for critical humidity and temperature measurements.
In this tutorial the interfacing of the HTS221 sensor module with arduino nano has been illustrated. To read the humidity and temperature values, we have used arduino with an I2c adapter.This I2C adapter makes the connection to the sensor module easy and more reliable.
STEP 1: Hardware Required:
STEP 2: Hardware Hookup:
The hardware hookup section basically explains the wiring connections required between the sensor and the arduino nano. Ensuring correct connections is the basic necessity while working on any system for the desired output. So, the requisite connections are as follows:
The HTS221 will work over I2C . Here is the example wiring diagram, demonstrating how to wire up each interface of the sensor.
Out-of-the-box, the board is configured for an I2C interface, as such we recommend using this hookup if you’re otherwise agnostic.
All you need is four wires! Only four connections are required Vcc, Gnd, SCL and SDA pins and these are connected with the help of I2C cable.
These connections are demonstrated in the pictures above.
STEP 3: Code for Humidity and Temperature Measurement:
Let's start with the Arduino code now.
While using the sensor module with the Arduino, we include Wire.h library. "Wire" library contains the functions which facilitate the i2c communication between the sensor and the Arduino board.
The entire Arduino code is given below for the convenience of the user:
<p>#include<Wire.h></p><p>// HTS221 I2C address is 0x5F</p><p>#define Addr 0x5F</p><p>void setup() </p><p>{ </p><p>// Initialise I2C communication as MASTER </p><p>Wire.begin(); </p><p>// Initialise serial communication, set baud rate = 9600 </p><p>Serial.begin(9600); </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Select average configuration register </p><p>Wire.write(0x10); </p><p>// Temperature average samples = 256, Humidity average samples = 512 </p><p>Wire.write(0x1B); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission();</p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Select control register1 </p><p>Wire.write(0x20); </p><p>// Power ON, Continuous update, Data output rate = 1 Hz </p><p>Wire.write(0x85); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>delay(300);</p><p>}</p><p>void loop() </p><p>{ </p><p>unsigned int data[2]; </p><p>unsigned int val[4]; </p><p>unsigned int H0, H1, H2, H3, T0, T1, T2, T3, raw;</p><p>// Humidity calliberation values </p><p>for(int i = 0; i < 2; i++) </p><p>{ </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write((48 + i)); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr, 1); </p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>data[i] = Wire.read(); </p><p>} </p><p>} </p><p>// Convert Humidity data </p><p>H0 = data[0] / 2; </p><p>H1 = data[1] / 2; </p><p>for(int i = 0; i < 2; i++) </p><p>{ </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write((54 + i)); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr,1); </p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>data[i] = Wire.read(); </p><p>} </p><p>} </p><p>// Convert Humidity data </p><p>H2 = (data[1] * 256.0) + data[0]; </p><p>for(int i = 0; i < 2; i++) </p><p>{ </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write((58 + i)); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr,1); </p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>data[i] = Wire.read(); </p><p>} </p><p>} </p><p>// Convert Humidity data </p><p>H3 = (data[1] * 256.0) + data[0];</p><p>// Temperature calliberation values </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write(0x32); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission();</p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr,1);</p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>T0 = Wire.read(); </p><p>}</p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write(0x33); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission();</p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr,1);</p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>T1 = Wire.read(); </p><p>} </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write(0x35); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr, 1);</p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>raw = Wire.read(); </p><p>}</p><p>raw = raw & 0x0F; </p><p>// Convert the temperature calliberation values to 10-bits </p><p>T0 = ((raw & 0x03) * 256) + T0; </p><p>T1 = ((raw & 0x0C) * 64) + T1;</p><p>for(int i = 0; i < 2; i++) </p><p>{ </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write((60 + i)); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr,1); </p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>data[i] = Wire.read(); </p><p>} </p><p>} </p><p>// Convert the data </p><p>T2 = (data[1] * 256.0) + data[0]; </p><p>for(int i = 0; i < 2; i++) </p><p>{ </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write((62 + i)); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 1 byte of data </p><p>Wire.requestFrom(Addr,1); </p><p>// Read 1 byte of data </p><p>if(Wire.available() == 1) </p><p>{ </p><p>data[i] = Wire.read(); </p><p>} </p><p>} </p><p>// Convert the data </p><p>T3 = (data[1] * 256.0) + data[0]; </p><p>// Start I2C Transmission </p><p>Wire.beginTransmission(Addr); </p><p>// Send data register </p><p>Wire.write(0x28 | 0x80); </p><p>// Stop I2C Transmission </p><p>Wire.endTransmission(); </p><p>// Request 4 bytes of data </p><p>Wire.requestFrom(Addr,4); </p><p>// Read 4 bytes of data </p><p>// humidity msb, humidity lsb, temp msb, temp lsb </p><p>if(Wire.available() == 4) </p><p>{ </p><p>val[0] = Wire.read(); </p><p>val[1] = Wire.read(); </p><p>val[2] = Wire.read(); </p><p>val[3] = Wire.read(); </p><p>} </p><p>// Convert the data </p><p>float humidity = (val[1] * 256.0) + val[0]; </p><p>humidity = ((1.0 * H1) - (1.0 * H0)) * (1.0 * humidity - 1.0 * H2) / (1.0 * H3 - 1.0 * H2) + (1.0 * H0); </p><p>int temp = (val[3] * 256) + val[2]; </p><p>float cTemp = (((T1 - T0) / 8.0) * (temp - T2)) / (T3 - T2) + (T0 / 8.0); </p><p>float fTemp = (cTemp * 1.8 ) + 32; </p><p>// Output data to serial monitor </p><p>Serial.print("Relative humidity : "); </p><p>Serial.print(humidity); </p><p>Serial.println(" % RH"); </p><p>Serial.print("Temperature in Celsius : "); </p><p>Serial.print(cTemp); Serial.println(" C"); </p><p>Serial.print("Temperature in Fahrenheit : "); </p><p>Serial.print(fTemp); </p><p>Serial.println(" F"); </p><p>delay(500);</p><p>}</p>
In wire library Wire.write() and Wire.read() is used to write the commands and read the sensor output.
Serial.print() and Serial.println() is used to display the output of the sensor on the serial monitor of the Arduino IDE.
The output of the sensor is shown in the picture above.
STEP 4: Applications:
HTS221 can be employed in various consumer products like air humidifiers and refrigerators etc. This sensor also find its application in a wider arena including Smart home automation, Industrial automation, respiratory equipments, asset and goods tracking.
