Introduction: Hunger Games Pin Fusion
Find an image of the hungergames pin on your browser and right clik on it and select save as. Then use the insert drop down and insert the picture
Step 1: Outer Ring
Use the 2 point circle tool in the sketch drop down. Creat a circle as closely to the center of the top and bottom of the pin's outer ring.
Step 2: Thickness
Stop sketch then go to sketch bar and select 2 point circle. Use a side veiw and slightly move the veiw to put the two points of the circle in the sides of the sketched ring
Step 3: Creat
Select the sweep tool in the create drop down. The path is the big circle's line and the profile is the small circle and than click ok.
Step 4: Sketch
Sketch all the lines on the drawing and use eny tool in the sketch drop down you can use with your knowlege
Step 5: Start Bird
Extrude all the inside of the lines to the hight of .30 inches
Step 6: Last
Extrude the rest of the insides of the bird to the hight of .25 inches
