Hydraulic Crane (Syringes) By: Mathias & Dennis
Intro: Hydraulic Crane (Syringes) By: Mathias & Dennis
This hydraulic crane is s school project, where we had to build a crane with synringes that could lift the higehst possible weight.
Materials:
1. MDF (600x600x6mm).
2. 1, 10ml syringes, 1, 20ml synringe and a tube who fits the end of the needles.
3. 3, M5 x 40mm bolt and nuts.
4. Any kind of thread who fits you.
STEP 1: Cutting Through the Skin.
We used a Laser Cutter, Its the fastest tool to cut out all these triangles.
As you can see it took us 21 min, to cut i all out on a 100 watt laser cutter.
STEP 2: Allready Time to Build!
Pircture 1:
Take one of the side. Put the wedge holders into the rektanguler holes. Then place the wedges to fasten them.
Picture 2:
Now put the piston plate (Rektangular plate with 3 holes) and the big wheel into place. Assemble them with one of the M5 bolts. Then you are able to place the syringe, it fits in the small rektangular hole. (you might have to cut a little bit in the syringe to make it fit).
Now you should assemble one medium wheel then the small wheel and one more medium wheel in the top right corner with a M5 bolt aswell.
Let's move on to step 3!
STEP 3: Final Step's
Picture 1:
Now you can put the thread around the big wheel. (If you grind a small crack its easier to control the thread)
Picture 2 + 3:
Now you can fasten the other side and the feets to make it stable.
Picture 4:
Connect both syringes with the tube and fill it with water:
Now its time to have fun!
STEP 4: Time to Play!!
Conclusion:
We are really happy for our final produkt, we love the design and how it works.
Out biggest problem is that when we pull the big syringe, and push the big wheel down. Then we pushed the plunge out of the small syringe, because the 2 long holes where too long. We pulled the object for about 50 mm. maximum should be 100 mm. Unfortunately we had no time to change it.
4 Comments
theoriginalrage 8 years ago
This is cool. I've wanted to try something like this for a while. Do you have a video or gif of it in action?
Dennis_deska 7 years ago
Thanks.
We dont have video, sorry.
Hunting Activity 8 years ago
It's easy and enjoyable, thank you for sharing your instructions.
KEAprojects 8 years ago
Thank your very much. Best Mathias & Dennis
