Introduction: Mini Aircraft Carrier
here is how i build the mini Aircraft carrier
air craft carrier
glass or something see through to make windows
Step 1: Boat
grab a box make the box length 123.00 the width 40.30 height 19.00 color the box grey it should look like the image above.
Step 2: Front of Boat
Grab wedge flip it 180 then turn it 90 to the left put it on the left side of the box change the height of wedge to 19.00 length to 40.30 it should look like the picture above. if not check again!
Step 3: Runway Part 1
Grab another box make the box length 142.54 the width 40.30 height 1.00 color the box dark grey raise it to 19.03 above the grey box it should look like the image above!
Step 4:
add yellow box put it right on the dark grey box length 20.00 width 5.98 height 0.25 and then duplicate it and move it a little forward and keep duplicating it until it looks like the image above.
Step 5:
then duplicate the the grey box in step one then put it next to it like this
Step 6:
add railings any of your choice raise it 6.43 length 65.74 width 1.51
Step 7: Runway Part 2
duplicate and turn it 90 then make the length 17.81 height 6.43 and the thickness 1.51
Step 8: Tower Part 1
duplicate box in step 5 and 1 then change the length to 59.15 and keep the thickness and the height same
Step 9: Stairs to Tower
duplicate box in step 8 and make the length 56.28 width 12.55 and stick a little out like the image above
Step 10: Hole to the Stairs
then group it to group it you hold your click to drag it to select all of it then press the icon the same as the image above. you might have to click on the image to see the arrow pointing at the icon to group.
Step 11: Color Ship
change color to multi color
Step 12: Door
make the door grab a block make the thickness 1.85 and the length 5.08 color it light grey it should be under the color white then place it to where it sticks through the wall for the stairs or ladder your choice i would go with stairs
Step 13: Door Handle
duplicate the door to make the door handle length 2.11 height 0.49 width 0.94 it should be like image above.
Step 14: Wall
duplicate the door make the width 1.51 and turn it 90 and then place it on the railing like the image above.
Step 15: Stairs
stairs take a box and make the width 7.99 length 53.42 height 1.17 and duplicate it and move the left side of it and keep duplicating it to make it stack then it should look like the image above. then group it.
Step 16: Wall for Stairs
take the copy of the door in step 14 and make it the wall should look like the second image
Step 17: Raise Back Wall
raise the wall should look like image above.
Step 18: Side Walls and Roof
add two more walls on the right and left side by duplicating the wall and making it the size of the left and right side of the communication tower then duplicate the sides to make the roof. like the image above.
Step 19: Radar and Decorations
add radar and decorations.
Step 20: Window and Jets
add the window and any jets you would like.
Step 21: Finish of Mini Aircraft Carrier
there you go now you have a mini Aircraft carrier careful unless you just want to break it or whatever material you use.
have fun and a good day.
