Introduction: I Make a Honey Bee From Wood and Resin
Check out the video for inspiration
This was a really fun but involved project. I used a bunch of familiar tools we all work with. It's the combination of these tools to get to the finish was interesting. I used a lathe to turn all the main body parts like the head, abdomen and thorax. I used the scroll saw, Dremel and sanders to shape the legs and wings. I also used resin to make the wings and the eyes. So there was a lot of smaller steps that I needed to tackle to get to the finished piece. You get the point. Check out the build video and below I'll show you an overview of the process.
Step 1:
My Bee sculpture is made from Walnut, Poplar and resin. I used a variety of tools to reach the finished piece. I used a table saw, wood lathe, scroll saw and Dremel. I also used epoxy to connect body parts together such as the antennas, legs and wings.
I started with the abdomen. I cut walnut and poplar wood into slices with the table saw.
Step 2: Glue Up of the Honey Bee Abdomen
I glued up the walnut and poplar wood and clamped them together. I set that aside for a few hours before going to the next step.
Step 3: Lathe Work on the Abdomen
I shaped the bee abdomen on the wood lathe. You can see it taking shape.
Step 4: Head and Thorax
I also needed to create the thorax and head of the bee. So I did that on a solid piece of walnut and used the lathe to shaped the parts.
Step 5: The Body Parts
I ended up with 3 oval shapes. I used a Forster bit to open a cavity for the 3 pieces to fit inside one another. Then I glued them together with 5 min epoxy and set it aside to work the next step.
Step 6: Leg Parts on the Scroll Saw
I printed out a bunch of leg parts for the bee and attached the templates to a walnut board. I then cut the leg parts out on the scroll saw and later used the Dremel tool and various sanders to shape them. I attached each leg piece together with 5 min epoxy.
I also used the Dremel to carve out below the thorax of the Bee. Here ( Build Video) I will attach the legs and use epoxy to bond the parts.
Step 7: Resin Wings
I mixed resin with gold mica powders and poured the mixture into a makeshift tray. Once the resin cured I pulled it from the tray and used sanders to clean up the cardboard that had bonded to the resin. This is what I made the wings out of.
I drew the shape of the wings onto the resin sheet and the cut the parts out on the scroll saw.
I used more resin to make the eyes. I shaped them with my Dremel tool. I took my time so both eyes would match in shape and size. I also attached them along with the antennas using more of the 5 min epoxy.
Step 8: Attaching the Wings
I attached the resin wings to the top of the thorax using more of that useful 5 min epoxy and held them in place til they bonded. This did take a bit of a steady hand and patience.
Step 9: Finished Honey Bee
Here are 2 shots for the Bee. It came out pretty cool. The video will showcase all the steps be sure to take a look. Honey Bee build video
Thanks!
