Introduction: I-Phone 6 Case
Instead of wasting another hundred and twenty bucks on a case that will break in five seconds, I decided to make a much more durable-adhesive, and cheap case myself. I got my "glue-guninator-2000" and assembled the case in two minutes.
Glue gun
(https://www.michaels.com/gorilla-dual-temp-full-size-hot-glue-gun/10671584.html)
Hot glue sticks
https://www.amazon.com/Sticks-Transparent-Adhesive-Bonding-Projects/dp/B07TVHSM8H
Iphone 6 (or whatever pocket phone you have)
Step 1:
The procedure is pretty simple, taking a maximum of 10 minutes, depending on the style. Please note that the steps may vary for your intended purpose.
- Get your glue gun. This project will require a minimum of three glue rods.
- Start placing the adhesive material on the back part of the phone. Do not cover any cameras, headphone or charging ports as well as volume outputs. Shape it however you please. Once this part is dry, go through the lateral sides Be very careful with touching the glue.
- If you want to decorate it, add some sparkles, drawings, or whatever you please.
- Congratulations! You have saved yourself billions of dollars from spending precious hours choosing a case that will end up in the trash a few seconds later. You have even customized your phone with decoration!
