Introduction: I2C Relay Board
Relays are one of the most common interfaces between a micro controller and the outside world. It provides electrical isolation between the low voltage circuits of the micro controller, and the loads.
So why this funny I2C Relay Board, you might ask....
With this instructable, I will try to give some of my reasoning behind the design of the I2C Relay Board.
Please enjoy, and any feedback is welcome.
Step 1: Normal Way to Drive a Single Relay
Normally, with a circuit driving only a minimum number of relays, the best way is to use a transistor driver circuit as shown. It is simple, low cost, and effective.
The resistors provide pull-down to ground, and transistor base current limitation.
The transistor is used to increase the current available to drive a relay. With only 1mA drawn from the micro controller pin, the transistor can switch a load of 100mA. More than enough for most types of relays.
The diode is a fly-back diode, protecting the circuit from high voltage spikes during relay switching.
The added advantage of using this circuit, is that the relay operating voltage can be different from the voltage of the micro controller. Thus, instead of using a 5V relay, one can use any DC voltage of up to 48V.
There is one drawback. Although the circuit only use 4 components, it all adds up quickly if more than about 4 relays are needed. So what to do if you want to drive 8 relays, but want to keep the PCB size as small as possible?
Step 2: Introducing the ULN2803
The more relays a project requires, the higher the component count. This will make the PCB design more difficult, and might use up valuable PCB space. But using a transistor array, like the ULN2803, will definitely assist in keeping the PCB size small.
The ULN2803 is ideally suited for 3.3V and 5V inputs from a micro controller, and can drive relays up to 48V DC.
This ULN2803 has 8 individual transistor circuits, each circuit fitted with all the components required to switch a relay.
Step 3: What We Have Achieved So Far
By using the ULN2803 driver, we reduced the component count to drive 8 relays from 32 components, down to a single component.
This will make the PCB design much more simpler, and reduce the overall PCB size.
Step 4: Connecting Relays to a Project Using ULN2803
This shows a project that drives 16 relays. As can be seen, the space taken by the ULN2803 drivers are minimal, and the pin layout of the ULN2803 made it very simple to incorporate on the PCB.
The headers to the right of the ULN2803 are used to connect to each relay. This makes the relay PCB simple, with only one supply connection, and one connection per relay.
So you may ask, is there any way to improve on this design...
Step 5: Intruducing the Microchip MCP23017 I/O Expander
The MCP23017 from MicroChip is an I/O Expaner IC, that adds 16 additional I/O ports to a micro controller. Each of the MCP23017 pins can be configured as an Input or as an Output. The MCP23017 is controlled via the I2C bus, and with programmable addressing on the MCP23017, up to 8 MCP23017 IC's can be connected to a project. This adds up to a total of 128 extra I/O pins.
Looking at the project where 16 relays are controlled, the number of wires between the main PCB and the relay board totals 17 wires - one relay positive supply, and one wire per relay.
Using the MCP23017, the wiring between the main PCB and relay board can be reduced to only 5 wires:
- relay positive supply
- +5V for MCP23017
- 0V
- SDA (I2C bus)
- SCL (I2C bus)
Best of all, to control the maximum of 128 extra I/O ports, it still only requires the same 5 wires from the main PCB. This makes for a simple and neat main PCB design, and reduces internal project wiring to a minimum.
Step 6: Designing of the I2C Relay Board
PCB Design software limitation
I am using the free version of Eagle for all my PCB designs. The software has only one limitation, and that is that the board size is restricted to 100mm x 80mm. For all my recent projects, this was acceptable.
Designing a single relay board with 16 relays and their screw terminals, was not possible on a 100mm x 80mm PCB. But it was possible to fit 8 relays with their terminal screws, a MCP23017 and ULN2803 on a single board. Instead of a single PCB, the design was changed to two identical PCBs. The only disadvantage with this option, was that instead of using all 16 I/O pins from a single MCP23017, each board had to be fitted with it's own MCP23017, and using only 8 of the 16 I/O ports.
Component selection
The design must be build using only standard through-hole components.
Connecting multiple I2C Relay Boards
The MCP23017 has three address lines (A0, A1 and A2), and each I2C Relay Board must have a unique I2C address. For easy addressing, header pins were added to set the address of each I2C Relay Board. With this option, up to 8 I2C Relay Boards can be connected to a project, to control a total of 64 relays.
Supplying power to the relays
With up to 64 relays that can be connected to a project, it is clear the power supply needed for the relays can no longer be taken directly from the main project PCB. Therefore, supply to each individual I2C Relay Board is done via screw terminals. To make it easy to loop the supply between I2C Relay Boards, two sets of screw terminals were
added.
Relay operating voltage
As there is a large selection of relays available, the design had to cater for different relay operating voltages. By using the ULN2803, the relay voltage can be between 5V and 48V DC. This makes selecting relays easier.
Connecting a load to the relays
A set of 3 screw terminals per relay allows easy connections the relay contacts (Common, Normally Open, Normally Closed). There is no common connections between the 8 relays, allowing maximum connection flexibility using the I2C Relay Board.
Connecting the I2C Bus
Connection of the four I2C Bus wires is done using headers. Again, two rows of headers were added for easy connection of multiple I2C Relay Boards.
Step 7: Cost and Design Breakdown
Using the project where I had to control 16 relays , the different designs can now be compared
Transistor design
32 Resistors, 16 Diodes (1N4007), 16 Transistors (BC109)
Total number of components excluding relays: 64
Total cost of components, excluding relays : ZAR116.96
Pros:
Standard everyday components
Cons:
Difficult PCB layout
17 wires between project and relays
ULN2803 design
2 x ULN2803
Total number of components excluding relays: 2
Total cost of components, excluding relays : ZAR18.24
Pros:
Minimum components
Easy PCB layout, and reduces overall PCB size
Cheapest option
Cons:
I2C Relay Board design
2 x ULN2803, 2 x MCP23017, 6 x 3-pin headers, 6 x mini-jumpers, 6 x resistors
Total number of components excluding relays: 22 (4 without the address selection headers)
Total cost of components, excluding relays : ZAR78.00
Pros:
Easy to connect multiple I2C Relay Boards to project
Only 6 wires between project and relays
Cons:
Not the cheapest option available.
Step 8: Connecting the I2C Relay Board
The project shown, uses 16 relays, so it contains two I2C Relay Boards. The address of the boards are set to 0 and 1 respectively. As can be seen, the connections between the different PC boards are now kept to a minimum.
Simply connect the +5v, 0V, SDA and SCL lines to an Arduino I2C Bus using ribbon cable.
Connect the required V-Relay to the board.
Step 9: Arduino and the I2C Relay Board
Connect the board to your Arduino as shown.
Below is a simple sketch for using the I2C Relay Boards.
In this sketch, only the "wire" library is used. Due to the easy comminucation on the I2C Bus, all comms to the MCP23017 is included in the sketch.
<p>#include <Wire.h> // needed for I2C operation<br></p><p>void setup() { //start I2C communications Wire.begin();</p><p> // Setup relay boards SetupRelays(); }</p><p>void loop() { // put your main code here, to run repeatedly: for (byte relaydata = 0; relaydata <= 255; relaydata = relaydata + 1) { // write data to cards 0 .. 7 relays WriteRelays(0,relaydata); // write data to relay card 0 WriteRelays(1,relaydata); // write data to relay card 1 WriteRelays(2,relaydata); // write data to relay card 2 WriteRelays(3,relaydata); // write data to relay card 3 WriteRelays(4,relaydata); // write data to relay card 4 WriteRelays(5,relaydata); // write data to relay card 5 WriteRelays(6,relaydata); // write data to relay card 6 WriteRelays(7,relaydata); // write data to relay card 7 delay(1000); } }</p><p>//++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ // Begin of MCP routines - no library needed </p><p>//++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++</p><p>void SetupRelays() { // Setup all possible relay cards (address 0 to 7) for (byte i = 0; i <= 7; i = i + 1) { MCP_Write(i, 0x00, 0b00000000); // set all pins to output MCP_Write(i, 0x12, 0b00000000); // set all outputs to off } }</p><p>void WriteRelays(byte address, byte data) { // Write data to relays // -------------------- MCP_Write(address, 0x12, data); }</p><p>void MCP_Write(byte MCPaddress, byte MCPregister, byte MCPdata) { // I2C write routine // ----------------- MCPaddress = MCPaddress + 0x20; // 0x20 is base address for MCP Wire.beginTransmission(MCPaddress); Wire.write(MCPregister); Wire.write(MCPdata); Wire.endTransmission(); } </p><p>//++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++</p><p>// End of MCP routines </p><p>//++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++</p>
Enjoy !
Step 10: Building and Selling This Project
If there is a company interested in building this I2C Relay Board, please do so. It would be great if this can be made available for hobbyist as a ready-made add-on.
s.
70 Comments
Tip 1 year ago
Thanks for this instructable. It inspired me to build my project. However, mine is based on Rpi Zero W, since I2C communication is the same. Few tips on handling MCP23017:
1. Check if the chip is not getting hot. Sometimes powering up the chip lead it to be misconfigurated: he issue appears to be that when one of the banks is set as an input and connected to a high source (i.e., 5v), about 20mv can sink into the chip. Use internal pull-ups or be sure how you configure.
2. MCP23017 use 3.3V and 5V, however, my experience is that powering with 5V leads to IO errors. 3.5-4V is sufficient. I am able to mange 8 MCP23017 effectively in one I2C line.
3. Using interuption signling via INTA and INTB (pins 19, 20 or 15 and 16 depending on the body) make the application design more complicated and is useless for application when only hmat interactions are required (like pressing the buttons). Just reading IODIRA and IODIRB in a loop is sufficient. TIP: slow down the loop with sleep/wait. Experiment with the values as this depends on number of chips and main procesor in use (Raspberry Pi for instance). Running RPi Zero W with 2-3 MCP23017's I use sleep between 0.02-0.04. Otherwise reading chips banks make no sense.
3 years ago
Can the 5v be substituted for 3.3v?
Question 3 years ago
in code where should i put the code for 32 relay?
3 years ago
nice project, thanks for sharing ?
4 years ago on Step 5
Nice tutorial - As per your question regarding premade i2c x 8 way relay boards
http://dcselectronics.co.uk//index.php?_a=product&product_id=23 may suit ypur requirements - will put up a picture when I can.
Question 5 years ago
So the 23017 has an A and a B side and you've only used B (I found out why in the comments). In my application I want to use both A and B sides so how do I write to A as well?
Additionally, how do you write to just one output as not to change the others. Say I wanted to turn on 3 but leave 4 and 5 on as they were, writing 00100000 would turn them off while switching on 3, correct? So how do I write only to one output without changing any others?
5 years ago
Very neat tutorial, well documented and very detailed! Can be used as a prototype example for many other tutorials.
There's one thing, however, I'm not in favour of: there's 220V (or the like) arriving at the board. I disencourage this. Better would have been to just provide terminal blocks on the PCB and then with small control cables go from the PCB to the real relais (e.g. mounted on a DIN rail or put on a completely separate PCB where there's no mix between low and high voltage).
Just my 2 ct.
Reply 5 years ago
Thanks for your comments.
The I2C relay boards can, and are used on a variety of systems, and not always on 220V. It was however designed for the following Instructable:
https://www.instructables.com/id/8-Channel-Program...
This relay board is the separate relay board, as you mentioned, for above project. The I2C was mainly used to reduce the number of wiring between the CPU board and relay boards.
As with any project, especially projects working of mains, the user should take the necessary safety precautions when working on the system.
Regards
Eric
6 years ago
Great Ible. Just curious why you did not make another board with just the relays and connect them to the other eight outputs on the 23017. Would have been relatively simple and would have saved 2 23017's. Or you could have used it to get 128 relays controlled.
Reply 6 years ago
Hi apburner
Glad you liked it.
The main reason I used I2C between the relays and main PC board, was due to output pin availability, and to reduce the number of wires.
If I had to connect another 8 relays connected to the 23017 to a second board, I would have ended up again with 8 additional wires between the boards.
Hope this answer your question.
Regards
Eric
6 years ago
Hi Eric. Wonderful work! Thanks for sharing this without copyrights!
implementing this will make automation with Blynk a very neat project, especially implementing an expansion board with a modular design.
I think you already know this, but can use fritzing to draw the boards. It will save you from the board size limitations of eagle ?
I have a question to you though: I am new to the field, with very very little experience. I see that the uln2903 is rated to a max output of 50v in the datasheet, which is ok to drive a 45v DC relay. I am assuming that this is the voltage of the output of the IC itself to the TTL control signal (and I might be wrong). There are relays available to drive 250v A/C with a current of 10A like KY-019. Would the current setup be sufficient to run such relays, or are the relays you have included are of a higher rating?
Thank you.
Reply 6 years ago
Hi, it is a pleasure to share...
Personally, I will not drive relays with coil voltages above 24V DC. The relays that was used in this project is rated at 10A @125V AC, or 8A @220V AC. This unitcan be used to switch the AC load directly.
REgards
Reply 6 years ago
Thank you for the quick response.
I think I was not clear in my question yet you answered me non the less.
I would not drive the relay coil with a voltage that high. most probably it will be the 5v supplied by the power source of the board. The relays I want to use once I start working on this will be used to run 240v AC, of course I need to figure out a way to have the whole thing running in parallel with the traditional switches and have an overide switch to change the whole thiny to manual should anything happen to the board.
So you recon the transistors should not have a problem with a relay even if it is rated to handle a higher ac current as long as the coil is being run with less than 50 v?
Thank you.
7 years ago
how do you use th i2c as i am new to it
Reply 7 years ago
See https://learn.sparkfun.com/tutorials/i2c for some information about the protocol.
7 years ago
Awsome instructable. where do you get the components so cheap?
Reply 7 years ago
I think most of the components were purchased from a local dealer.
www.rabtron.co.za
7 years ago
Guy! Very good your project. I will test and deploy. Congratulations.
Reply 7 years ago
Thank you.
7 years ago
If I had an AC signal(say a 1000hz audio signal) that i wanted to use to switch on a relay, is there a relay that can do that?
