Introduction: IC555 LED Dimmer! | DIY
Hi guys!
In this Instructable, I'll be showing you how to make LED strip dimmer using a few potentiometers and an IC555 timer. I'm currently working on a larger project which involves using this circuit, So I thought it would be good to share this circuit since it's really cool to play with just by itself.
So let's get Started!
Step 1: Watch the Video!
If you don't want to read all the stuff you can watch my video!
Step 2: Part List, Schematic & Gerber Files!
Part List:
Tools:
- Soldering iron
- Side cutters
- Pliers
- Multimeter
Optional:
Since I will be using this circuit for a future project I decided to go for PCB you can do it on a Vero board
Step 3: Working!
Working of LED Dimmer using IC555:IC555 is capable of generating PWM signal which can control the amount of power delivered to the circuit. Pulse Width Modulation (PWM) is a fancy term for describing a type of digital signal.
When the signal is high, we call this “on time”. To describe the amount of “on time”, we use the concept of the duty cycle. Duty cycle is measured in percentage. The percentage duty cycle specifically describes the percentage of time a digital signal is on over an interval or period of time.
If a digital signal spends half of the time on and the other half off, we would say the digital signal has a duty cycle of 50% and resembles an ideal square wave. If the percentage is higher than 50%, the digital signal spends more time in the high state than the low state and vice versa if the duty cycle is less than 50%.
Here graph that illustrates Four scenarios:
100% Duty Cycle= avg 5V
75% Duty Cycle= avg 3.75V
50% Duty Cycle= avg 2.5V
25% Duty Cycle= avg 1.25
Step 4: Soldering!
Soldering is pretty easy and straight forward start with IC then capacitor followed by Resistor and finally add the MOSFET! and you are done!
Step 5: Power Everything and Test!
Once done power every and you are ready to go!
If you like my work
Feel free to check out my YouTube channel for more awesome stuff:
https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects
https://www.facebook.com/NematicsLab/
