Introduction: ICStation FM Radio Soldering Kit With LED Lights
Introduction:
Description:
It is an RDA5807 87.0MHz-108.0MHz Wireless FM Radio Receiver DIY Kit with RGB spectrum indicator flashing automatically.
It has a LCD1602 display screen which can clearly display the receiving frequency.
Feature:
- Built-in volume adjustment
- RGB spectrum indicator flashing automatically
- Support 87Hz-108MHz receiver frequency
- Built-in 5W power amplifier
- LCD1602 display screen
Parameter:
- Product Name:RDA5807 FM 87-108MHz Radio Receiver LCD1602 DIY Kit
- Work Voltage:DC 4.5V~5.5V
- Output impedance:4ohm
- Output power:5W
- Output channel:Mono
- Receiver Frequency:87.0MHz~108.0MHz
- Frequency accuracy:0.1MHz
- Equivalent noise: >=30dB
- Work Temperature:-40℃~85℃
- Work Humidity:5%~95%RH
- Size(Installed):90*70*55mm
Practical DIY Kit
This is a radio electronics soldering kit, come with a package of electronic components and shells, users need to use soldering tools (not included) for assembly.
Perfect for electronics hobbyists and beginners to learn soldering skills and abilities while getting a practical radio.
LCD Display
Equipped with high-definition LCD screen, after the assembly is completed, you can freely adjust the frequency you want to listen to and the volume you need through the buttons below the radio.
Cool LED Lights
In addition to having the basic functions of a radio, it is also equipped with 10 LED lights, when you listen to the radio, these LED lights will randomly flash different colors of light and beat with the radio sound, making your DIY radio unique.
Great Gift
Maybe you also want to DIY a small gift ? To your friend or family member? This radio DIY electronics kit might be a good choice. It is also protected by an acrylic transparent case, which not only looks beautiful, but also protects the components inside from external damage
Step 1: Install 1pcs SMD Components RDA5807 FM Receiver at U2
Note: PCB has 2 versions: Older version comes with blue RDA5807 receiver. Newer version comes with green RDA5807 receiver.
