Introduction: ICT Proyect Homemade Dice by Andres Arze Alejandro Plaza and Andres Antelo
How to make a homemade dice.
Tinkercad
Paper
Scissors
Ruler
Markers
3D printer (opcional but for a
Step 1: Step 1
First go into tinkercard and start by selecting a cube.
Step 2: Step 2
continue by changing the size from 20 to 75 on width and height.
Step 3: Step 3
Continue by giving the cube a radio of 1 or a little bit more.
Step 4: Step 4
continue by changing the color of the cube to a white.
Step 5: Step 5
Next use the Work Plan and put it on one side of the cube
Step 6: Step 6
Now change your view until it looks like on the picture
Step 7: Step 7
Continue by selecting a sphere and put it somewhere in the middle
Step 8: Step 8
Change the sphere color to black
Step 9: Step 9
The spheres height put it on -13 so it looks merged on the Cube and repeat this process until it looks like a normal cube
Step 10: Step 10
Get a white paper and draw a 20cm horizontal line and a 5 cm vertical line.
Step 11:
make a mark on the first 5 cm 10 and 15 in the horzontal line
Step 12:
Make another vertical line on the right and make the close it so it makes a rectangle.
Step 13:
Make a Straight vertical line in the points you marked before
Step 14:
In the 5cm mark and the 10cm mark add up 5 cm up and 5cm down and close it with a horizontal line like this
Step 15:
Make some lines around the boxes like this
Step 16:
Start making the Numbers for the dice like this and in this order.
Step 17:
Cut it with some scissors carefully like this.
Step 18:
In the lines you have on the shape start bending them in the shape carefully and it will start to get a cube shape like this
Step 19:
Start by putting glue on the outsanding pieces
Step 20:
Paste all the outsanding pieces together until it end like this.
Step 21:
Once done just color the numbers with a black marker and you are doneeee.
