Introduction: IKEA HACK: Easy Lamps
Ikea has plenty of things that can be turned into attractive lights. I loved the industrial look of the stainless steel colander, and turning it into a lamp was a breeze with IKEA's inexpensive Hemma light socket set.
At $15, this easy project can be remixed and remade in countless ways.
Step 1: Supplies
I wanted to try a few different kinds of lights using this concept, so I grabbed a few types of stainless steel enclosures:
$5.00 HEMMA cord and light socket set
$9.99 ORDNING stainless steel colander
Step 2: Drill Opening
Going at a low speed on a drill press and using plenty of lubricant, a 1-1/4" hole saw was used to create an opening in the bottom of the colander. The same process was repeated on the stainless steel candle holders.
Step 3: Disassemble Socket Set
The light socket set has a collar that threads into the neck of the socket. Unscrew the collar and feed the neck through the opening of the colander, then screw the collar back on the neck securing the socket to the colander. After, install a light bulb into the socket.
Repeat this same process with the stainless steel candle holders.
Step 4: Hang Lamps
To hang your lamp you'll need a ceiling hook or beam to drape the power cord through, then plug into the wall directly or into a power switch.
Let there be light!
