Introduction: IKEA SEKOND Pendant Moon Lamp
This instructables show how to use IKEA SEKOND Cord Set to make a 8 Inches Pendant Moon Lamp.
Step 1: Preparation
Any color variation is ok:
White textile: https://www.ikea.com/hk/en/catalog/products/603863...
Red textile: https://www.ikea.com/hk/en/catalog/products/50386...
E27 Light Bulb
IKEA SEKOND cord set rated support max 22W light bulb, white light or warm light depends on your preference. However, since the Moon lamp shade is a closed sphere, unlike other lamp shade, you cannot put on and off the light bulb after screw up the cord set. The only hole of the Moon lamp shade is the screw socket for the cord set. So beware the diameter of light but should not larger than that hole, i.e. 38 mm.
Step 2: 3D Printing
Please download and print the Moon lamp shade from thingiverse:
https://www.thingiverse.com/thing:3532973
I have tried over an month for successfully print the Moon lamp shade. Here is some notes about that:
- Slic3r introduce too much stringing on the over hang part
- Don't use poor quality filament, it waste too much time for unexpected problems
- Prusa Stealth mode very easy to loss steps
- Turn on Collision detection can recover some loss steps
And here is my success settings:
- Cura 4.0 with imported Prusa i3 MK3 profile
- 0.15 mm layer default setting
- 100% infill
- no support
- no adhesive
- use masking tape increase surface adhesive
Step 3: Screw Up
- Screw up the light bulb to the cord set
- Screw up Moon lamp shade to the cord set
Step 4: Happy Home Decoration!
It's time to enjoy your sweet home ;>
8 Comments
2 years ago
What brand and filament type did you find worked for you?
Reply 2 years ago
Any white PLA should be ok, I am using 86duino white PLA filament.
Reply 2 years ago
Thanks for that reply. 86duino doesn't appear to be available to me here in the USA. I think I will use 3D Solutech.
I have another question. In your write-up you say, "Cura 4.0 with imported Prusa i3 MK3 profile", could you share the file you used to import into Cura? I also have a Prusa i3 MK3S+ printer. I see an option in Cura Preferences:Profile to import profiles, however I don't see any profile formats here I can Export from PrusaSlicer.
Tip 3 years ago
good
3 years ago
Very Nice
3 years ago on Introduction
Nice!
3 years ago
did you use PLA or PETG?
3 years ago
This is the best product that IKEA makes, thanks for sharing this, I just favorited it!
