IKEA VINDRIKTNING + BME280 + D1mini
Intro: IKEA VINDRIKTNING + BME280 + D1mini
Enhance IKEA Sensor by adding Temperature, Pressure and Humidity sensor (BME280)
STEP 1: Download and Install ESPHome Locally
Install docker.io
debain based: apt install docker.io
Download ESPHome docker image
docker pull esphome/esphome:latest
Create an alias for esphome docker command
edit ~/.bashrc and add the following line alias esphome='docker run --rm -v "${PWD}"/esphome-config:/config --device=/dev/ttyUSB0 --net=host -it esphome/esphome'
As root add your user to the docker group
usermod -a -G docker <your user>
STEP 2: Run ESPHome
Run in terminal as your user
esphhome
Access the esphome gui
http://localhost:6052/
STEP 3: Add the Sensor
Add the new sensor and install the initial firmware
Install by selecting Plug Into The Computer Running ESPHome Dashboard
Edit the sensor and put the following code
esphome: name: bedroom-sensor esp8266: board: d1_mini # Enable logging logger: i2c: sda: D6 scl: D5 scan: False # Ikea Vindriktning PM2.5 sensor uart: rx_pin: D2 baud_rate: 9600 sensor: - platform: bme280 temperature: name: "BME280-1 Temperature" oversampling: 16x pressure: name: "BME280-1 Pressure" humidity: name: "BME280-1 Humidity" # Address is not default! address: 0x76 update_interval: 60s - platform: pm1006 pm_2_5: name: "Ikea Vindriktning PM25" filters: - sliding_window_moving_average: window_size: 10 send_every: 10 # Enable Home Assistant API api: ota: wifi: ssid: !secret wifi_ssid password: !secret wifi_password fast_connect: true # Enable fallback hotspot (captive portal) in case wifi connection fails ap: captive_portal:
STEP 4: Solder All of the Components
From D1mini to BME 280
3v3 pin ground pin D5 to SCL D6 to SDA
From D1mini to pm1006
5V pin Ground D2 to REST
Kimotu 1 year ago
