IPhone 7 Display / LCD Replacement By robert9stark1 in WorkshopRepair6421Introduction: IPhone 7 Display / LCD ReplacementFollow the steps from the guide to replace your display!Step 1: Remove the Two 3.4 Mm Screws on the Bottom Edge of the IPhone.Step 2: Attach a Suction Tool to the Lower Half of the Display Assembly.Step 3: Pull Up on the Suction Cup to Lift the Display UpStep 4: Remove the Following Four Screws.Step 5: Remove the Two Screws Securing the Bracket Over the Front Panel Sensor Assembly Connector.Step 6: Disconnect the Two Lower Display Connectors.Step 7: Remove the Three Screws From Either Side of the Display.Step 8: Remove the Three Screws Securing the Earpiece Bracket.Step 9: Remove the Four Screws Securing the Bracket.Step 10: Lift the LCD Shield Plate From the DisplayStep 11: Remove the Earpiece Speaker.Step 12: Remove the Home/Touch ID Sensor.
