Introduction: IPhone X Pop-up Greeting Card
In this instructable , I will show you how to make an iPhone X Pop up Greeting card
Step 1: Learning the Basics : Types of Fold and Scoring
Other than cutting you will need to make folds for your objects to pop up
There are two types of folds :
1)Valley fold : This fold usually makes a right angle and the the two portions of the paper make a shape of a Valley.
2)Mountain fold : This fold usually makes a 270 degree angle and it is reverse of valley fold . The two portions of the paper make a mountain.
In a simple pop up card , the ratio of valley folds to mountain folds is 3:1 . This ration usually works out in even complex objects though it may somtime become 2:1 or even equal
To establish the folds , we need to score the paper . Scoring is partially cutting the paper (cutting about 1/3 of paper ) but instead of cutting partially , I just like to crease the paper.
There are proper tools for scoring , exanple - teflon bone folder .Though I just use a compass for it as it works great on thick paper (it cut through too thin paper )
Step 2: Learning the Basics : How the Objects Actually Pops Uu
To make the object Pop up corectly , basic theory is that the vertical lenght of the support paper strip(horizontal lenght depends on the object ) should be same as the the distance of the base of the object from the centre crease .
The above image will explain the what I am trying to say
Once you have understand that , you are ready to make a Pop up iPhone X greeting Card.
Step 3: Gather the Materials
To make the iPhone X Card , you will need the following materials :
● A4 Cardstock : 1x white and 1x colored ( I recommend using 200-300 gsm cardstock)
● Craft knife (or X acto syle knife)
● Pencil and eraser
● Ruler
● Set square (I use this more than the ruler)
● PVA glue (Elmer's , Tacky glue etc.)
You will also need to make a template of iPhone X outer dimension with curved corner
Dimension are ~140mm x 70 mm though that would be too big for card so i am using 120mm x 60mm dimension (It still maintain the 2:1 ration of the phone)
4 Comments
5 years ago
Fun way to make personalized card. Thanks for sharing.
Reply 5 years ago
Thank you
5 years ago on Introduction
In step 3 , in the last I mean RATION not ration
Reply 5 years ago
*RATIO Not ration
