Introduction: IR Relay Control
This project shows a simple way to detect a near object (like a model train passing) and activate a relay.
5 volt relay module
IR detector module
Step 1:
Make sure the little yellow jumper is placed close to the "L" end (the IR sensor goes low when it detects an object).
Step 2:
Connect according to this schematic. The power supply used is 5 volts dc. The small blue potentiometer can be turned to adjust sensitivity.
Step 3:
When the object is close, the relay will close (note the small red light on the relay module). When the object is not close, the relay will open.
