Introduction: IR Remote Home Control Using the KY-022
Hello again!, I created a home control using the HX1838 IR Remote and the KY-022 IR Receiver.
I added some relays to it which act as rooms, devices, or lamps, and a 3 color rgb led which act like a Led strip.
+ a simple buzzer for no reason at all! :) check the following step.
Step 1: Schematic Code & Parts List.
Just connect it like the schematic, and it should work.
Parts list:
- IR Remote HX1838
- IR Receiver module KY-022
- RGB Led Module KY-016
- 4 Relays KY-019
- Buzzer
- Set of Jumper wires MM/FF/MF
- Lamp fittings + lamps (Optional)
- Arduino UNO, I used RobotDyn UNO a chinese copy with 7 analog pins.
The code has Explanation inside to. I hope you understand. Its pretty basic.
Good luck!
