Introduction: IR Sensor Button
This is an easy way to make a infrared sensor button with the Arduino.
This example shows a infrared sensor button with an integrated light. If you touch the surface then the button lights red. Touch the surface again, then the light turns off.
The first image is a design example.
Step 1: Circuit
To change the intensity of the Phototransistor (T1) use an another resistor for R4.
Step 2: Parts List
D1           IR LD271
D2           LED 500 red
K1           male connector 4pins
R1           10KOhm
R2,R3      100 Ohm
R4           510KOhm
T1           SFH300FA
T2           BC547A
Step 3: Arduino Sketch
The Arduino Code is very simple:
#define ACTIVATE_VALUE 750  // Change this value for an another distance
#define PRESS_THRESHOLD 250
int SENSOR_VALUE;
byte ON_OFF = 0;
void setup() {
  Serial.begin(9600);
  pinMode(2, OUTPUT);
  pinMode(A0, INPUT);
void loop() {
  SENSOR_VALUE = analogRead(A0);
  Serial.println(SENSOR_VALUE);
  if (SENSOR_VALUE > ACTIVATE_VALUE) {
    digitalWrite(2, ON_OFF = !ON_OFF);
    delay(PRESS_THRESHOLD);
  delay(100);
Step 4: Example
The case I have printed out on a 3D-Printer. The top plate is an 31x31x3mm Acryl-Glas. My button is 35x35x20mm big. The distance from the IR-Diod to the acrylplate is ~6mm.
With a sheet of sandpaper I have made the surface of the acrylglas diffuse.
Youtube: www.youtube.com/watch?v=L9-gg7UPTqw
