Introduction: ISS Tracking Lamp
Most of the time, i'm wondering where is the ISS looking up the sky. To answer this question, i've made a physical object to know exactly where is the ISS in real time.
The ISS Tracking Lamp is a Internet connected lamp which constantly tracks the ISS and displays it location on Earth’s surface (printed in 3D).
Bonus: the lamp also displays the sunny side of Earth with Neopixels!🌎🛰
So, in this Instructables, we are going to see the differents steps to build this lamp based on WEMOS D1 Mini, stepper motor, servo motor, laser and 3D parts.
I build all by myself, except for the 3D printed Earth, which was purchased on Aliexpress.
Software :
- Arduino based code
- API ISS Location : Open Notify - Current Location of the ISS (by Nathan Bergey)
- Parsing data : ArduinoJson Library (by Benoit Blanchon)
CAD & Parts :
- 3D Printed Earth of 18cm diameter (purchased on Aliexpress : here )
- 3D printed motor supports - designed with Fusion 360 and printed with Prusa i3 MK2S
- Copper tube
- Concrete base, made with The French Vikings
Hardware :
- Microcontroller : Wemos D1 Mini (wifi antenna integrated)
- Servo EMAX ES3352 MG
- Stepper Motor 28byj-48 (with the ULN2003 driver board)
- 10 NeoPixels LED
- Laser of 405 nm wavelength
- Limit Switch
- 5V 3A Power Supply
Step 1: Modeling Parts in Fusion 360 and Printing
To mount all the hardware, we are going to create the core assembly base on 3D parts. The parts are available on Thingiverse here.
There are 3 parts :
1) The Support Stepper Longitude
This part is made for mounting the stepper motor, the WEMOS, the Neopixels strip and the copper tube
2) The Support Switch
This part is made for mounting the limit switch (use to indicate to the stepper the latitude -0°/-180°). It's screwed on the top of the stepper
3) The Support Servo Latitude
This part is made for mounting the servo motor. The Support Servo is mounted on the stepper motor
All the parts were printed on Prusa I3 MK2S, with black PETG filament
Step 2: Wiring and Assembling
This circuit will have a 5V 3A power input (in order to use the same supply for the stepper driver, the laser, the Neopixels and the WEMOS)
By the following Sketch, we need to solder the power supply directly to the elements above in parallel:
- Stepper Driver
- Laser
- Neopixels strip (NB : there are 10 Neopixels in reality, not 8 as the sketch shows)
- WEMOS
Next, we need to connect the different elements to the WEMOS :
1) The stepper driver following this list:
- IN1->D5
- IN2->D6
- IN3->D7
- IN4->D8
2) The servo motor following :
- Data Servo Pin -> D1
3) The Neopixels strip following :
- Data Neopixels Pin -> D2
4) The limit switch following :
The two pins of the switch to the GND and D3
Connect the limit switch in a manner that the circuit is opened/broke when we push on the switch (so the circuit is closed when nothing push on it). This is to avoid any wrong lecture due to a voltage peak.
Step 3: Arduino Code - Getting the ISS Position in Real Time
To drive the two motors to reach the position of the ISS, we need to get the position of the ISS in real time :
- For that first we will use the API from Open Notify Here
- Then, we need to parse the data to get simple value of the ISS location with the help of Parsing data : ArduinoJson Library (by Benoit Blanchon)
#include <ESP8266WiFi.h #include <ESP8266HTTPClient.h #include <ArduinoJson.h // WiFi Parameters const char* ssid = "XXXXX"; const char* password = "XXXXX"; void setup() { Serial.begin(115200); WiFi.begin(ssid,password); while (WiFi.status()!= WL_CONNECTED) { delay(1000); Serial.println("Connecting..."); } }
This program connects the NodeMCU to the WiFi, then connects to the API, get the data and print it to by serial.
void loop() { if (WiFi.status() == WL_CONNECTED) // Check WiFi Status {HTTPClient http; //Object of class HTTPClient http.begin("http://api.open-notify.org/iss-now.json"); int httpCode = http.GET(); //Check the returning code if (httpCode >0) { // Parsing const size_t bufferSize = JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + 100; DynamicJsonBuffer jsonBuffer(bufferSize); JsonObject& root = jsonBuffer.parseObject(http.getString()); // Parameters const char* message = root["message"]; const char* lon = root["iss_position"]["longitude"]; const char* lat = root["iss_position"]["latitude"]; // Output to serial monitor Serial.print("Message:"); Serial.println(message); Serial.print("Longitude: "); Serial.println(lon); Serial.print("Latitude: "); Serial.println(lat); } http.end(); //Close connection } delay(50000); }
Step 4: Final Arduino Code
The following Arduino code get the ISS location to move the laser to the right place on the Earth's surface, and the getting the position of the sun to light up the concerned Neopixels to light up the surface of the Earth touch by the sun.
Bonus 1 : When the lamp is switched on, during the phase of initialization, the laser will point the position of the lamp (id : the position where the router is)
Bonus 2 : When the ISS is next to the lamp location (+/- 2° long. and +/-2° lat.), all the Neopixels will gently wink
Step 5: Enjoy Your ISS Tracker
You have made a ISS Tracking Lamp, enjoy!
First Prize in the
First Time Author Contest
113 Comments
3 months ago
i love to make this as well, but the code is no longer working ?
3 years ago
Hi, excellent project.
I have made the thing and it works without modification. I only used a different globe: https://www.thingiverse.com/thing:4046428 and added a 3d printed stand.
Only problem I see is that sometimes the vertical servo takes a dip, but corrects itself after a while. I have not investigated why, but it would be good if someone correct this and post an updated code.
Reply 3 months ago
by any chance, do you have a link for the limit switch your using?
Reply 3 years ago
oh wow! So happy to see a second Iss tracker Lamp build! Congrats, looks gorgeous
4 months ago
This is exactly I am planning to build...thanks...but I'd like to add a pointing function - to show any place on Earth
3 years ago
Hello Antoine,
A great Project did you make - very cool!
i made a small PCB with the same dimension of an Wemos with all the components on one PCB.
It is better for wireing the components.
best regards to all!
Reply 2 years ago
could you publish or send me your work? I am struggling with the build, and your design would be great. What can I do for you?
Reply 2 years ago
Hi,
you can get a PCB or the whole PCB with Components !
Where did you came from?
Br
Robert
Reply 2 years ago
my replies seem to be disappearing.
I would like the obtain the bare board without componets; how can I do that? do you have an email?
Reply 2 years ago
USA here. Where can I get the PCB?
Reply 2 years ago
Hi,
i
I can send the working PCB without firmware and you can flash it yourself!
or i send you the PCB with the components or without the components.
br
Robert
Reply 2 years ago
my email address is ckigar@hexnut.us
please provide pricing and details
Reply 2 years ago
I would prefer the PCB without the components. I have already acquired all of them (the arduino, controller, etc.) Wiring them all up is messier that I'd like so I would like to use the PCB.
What can I do for you? Paypal? How can we do this?
My email is ckigar@hexnut.us
Let's move this discussion to email.
Reply 3 years ago
Wow, that's better and more elegant :)
Question 2 years ago
Hey, amazing project, may I know where you got that lazer from?
Answer 2 years ago
Amazon
please link the parts listed to place to buy them
3 years ago
Whats does this piece of Code do?
//Positioning at -179°
float x_pas_calibration = (motorSteps_360_degres * 1 * 1000 / 360);
int x_pas_int_calibration = ceil(x_pas_calibration);
stepper.step(x_pas_int_calibration);
Position_Longitude_Laser = -179;
delay(20000);
Reply 3 years ago
This piece of code positionned the motor at -179 after it drives back at -180.
When the motor drives back, it starts from -179° (do a full turn) and stops at -180 (when hitting the switch button). But -180 is not correct because its -179° the real value of the ISS. So just moving the motor 1° back to be as precise i can be
Reply 3 years ago
Thank you, for the explanation.
