Introduction: Ibá Pendant Light
Ibá is an indigenous word from Tupi language that means:FRUIT.
I created this pendant to play with the lights and shadows in the enviroments, bringing a little drawing with Brazilianness.
POWER PLUG
PARALLEL WIRE
E27 SOCKET
BULB E27
Step 1: Design 3D Model
First, I defined the maximum size i would like to work with. And its format with the vertical axis of symmetry.
With the Fusion360 software, i created the 3D modeling.
Step 2: Slicing 3D Model
Then, i sliced the 3D model in two directions: Horizontal (X-axis) and vertical (Z-axis) considering the thickness of the material to be cut. (In this case 3mm MDF Wood).
Step 3: Flattening the 3D Model ----> 2D Model
With all parts defined and flattened, i was able to export the 3D model to a 2D file - considering only the vectorized lines.
Step 4: Cutting, Fitting and Assembling
Then it was time to export the pieces to a Laser Cutter... to cut the pieces individually.
After cutting all the pieces, i started fitting them, following the named order.
Step 5: Customize and Create the Electrical Installation
Finally, you can create the eletrical circuit and add E27 lamp of your choice.
You will be able to customize your pendant painting it in a different color, changing the color of the lamp, or even placing an RGB LED lamp.
Step 6: Enjoy It !
I hope you like it. Thanks
It's my first instructable. See you soon !
