Ice Cream Cone Cake Pops
Intro: Ice Cream Cone Cake Pops
Here's a bit of Spring and Summer before it arrives. This is a great recipe for those who struggle with cake pops. Once the cake is on the cone, the lollipop sticks can be removed and the cake will still hold up beautifully. Watch the fun video tutorial above to see all details come together and join me on YouTube.
Ingredients:
Cake (I used a frosted slice)
Buttercream (if using un-frosted cake)
Candy Melts (I used off white and pink)
Sprinkles, Jimmies, Etc. Chocolate
fudge
Ice cream Cones
Lollipop Sticks
STEP 1: Form the Dough
In this video I used a big slice of cake that was already decorated and frozen. Therefore, I didn't add any icing to the cake because it was already frosted. But if you're using un-frosted cake, just add a couple spoonfuls of icing until you are able to form a good cake dough. The consistency should literally feel like dough or clay.
STEP 2: Cake Balls
Once the dough is together, form golf ball sized cake balls. You can also use your ice cream cone for measurement. It should sit right into the cone without expanding too far out.
For double scoops, make another set of cake balls but flatten one side slightly, light a half moon. These won't need a stick.
Once you've formed the balls, melt some of the candy melt. Dip the lollipop stick 1/2 in. into the candy melt and push half way into the cake ball. For top scoops, this step won't apply.
Put cake balls into the freezer for 20-30 minutes or the refrigerator for 1-2 hours.
STEP 3: Dazzle Those Cones
We're going to need a small hole at the bottom of the cone for the stick. With a knife, carefully cut off the tip. Make sure the stick will go through before doing the next step.
While those cake balls are setting up, jazz up the ice cream cones by dipping the rim into candy melts. Let excess fall back into the candy melt then dip into confetti candy or sprinkles.
Using a toothpick (or the back end of a paint brush like I did) add dollops of candy melt to the top of the cone to look like melting ice cream. Allow to harden for 5 minutes.
STEP 4: Cone It
Once the cake balls are ready, carefully dip each pop into the candy melt. Place the cake pop into the cone. The stick should go through the bottom of the cone. Gently pull the stick allow for the candy melt from the cake pop to melt onto the cone.
If doing one scoop cones, here you can add sprinkles and jimmies.
STEP 5: Double Scoop
For top scoops, use a fork to dip into the opposite color candy melt as the first scoop. Cover as much as you can, and place on top of the ice cream cone cake pop. Hold the top scoop in place for a minute until the candy melt hardens.
Add a little bit of candy melt to the top of the scoop to cover up fork holes.
STEP 6: Toppings
While wet, top the cake cones with sprinkles and all sorts of candies. I also cut a red jelly bean in half to use as a cherry. For the sundae look, add some melted chocolate and let drip down.
At this point, you can remove the stick if you'd like. The scoops will stay perfectly onto those cones!
Join me on YouTube, by clicking the video tutorial above and subscribing. I'd love to see you there.
Enjoy!
5 Comments
MS71 8 years ago
Those are the most beautiful cake pops I have ever seen. Wonderful job!!:)
Marishas Couture 8 years ago
RandaG 8 years ago
woooooow <3
emily1008 8 years ago
u know what u talking about
Berwyn ILLocksmith 8 years ago
Thanks for reminding
