Introduction: Ice Tyres for a Mountain Bike
We have had some bad weather recently and all the cycle paths round my part of the world are covered in several inches of ice which makes cycling a pain. So I decided I needed a pair of ice tyres for the once a week trip into the office.
After researching how ice tyres worked, what a couple of the manufacturers offer and the DIY versions on here, I went down my workshop and found some self-drilling carbon tipped pan head screws used for fixing flat surfaced hardware to reinforced PVCU windows and a couple of spare tyres that came with a bike ages ago.
Step 1: Parts List
The parts list for this project was really simple and whatever I had on the shelves:
2 Tyres (Tires)
200 Screws
Glue
Old inner tube
Tools
Bradawl (or other hole making device - yes I used a scribe)
Screwdriver
Step 2: Add Some Spikes
After a little trial and error I found that using a sharp point to puncture the tyre (from the outside) in exactly the place I wanted the spike to come out, allowed me to just push the sharp end of the screw threw the tyre from the inside, the end result was a nice uniform double row of carbon steel zinc plated spikes, threaded into the chunky rubber part with no hope of being pulled out.
The screws stick through the rubber on these tyres about 10mm which if I am being honest is about 5 more than I really wanted but without buying chunkier tyres or shorter screws that's not going to change.... and I like the slightly excessive look.
At this point I started being paranoid about pushing a screw back into the tyre and shredding a perfectly good inner tube whilst riding.
So I coated every screw head with strong flexible glue and then glued an old inner tube over the glued screw heads. I can also guarantee that the good inner tube isn't stuck to the glue when it is time to change it again.
This whole process took just under two hours per tyre to fit two rows of 50 screws in each, this lined up with the tread pattern and as I am not heading anywhere remotely uneven I decided the outer edges of the tyre were best left un-spiked and if the grip wasn't good enough I could always spike the central row of tread too.
I decided to inflate the experimental tyres to 40psi as this was the lowest manufacturer recommended setting so if the spikes needed to flex a little they could without ripping the rubber blocks apart.
Step 3: Ride
After a nice little round trip of 5 miles in freezing conditions I can report that the riding experience on Ice is amazing, you have total control and complete confidence in applying the brakes. Acceleration has to be controlled as it's still possible to loose traction if you are powering up hill and the only problem I found was the groves left by other people can cause a little wobble if you aren’t concentrating, but you can comfortably climb out of them whenever you like.
Riding on cleared sections or crossing main roads is very noisy and a little slippery compared to the ice but completely controlled, I now understand the description of 'sounding like being chased by a pack of dogs', but I would also describe it like the first sound a flat tyre makes, it was enough to make me stop and check the pressure!
I love the look of the tyres although was very careful not to run into anything/anyone as the sharpened spikes would do some amazing damage. (If you build a set of these I am not responsible for what you do with them.)
Both tyres kept their pressure and although they feel double their original weight there is no other way to ride on ice.
23 Comments
9 years ago on Introduction
I made some of these in 1998, using a recipe from our local outdoor store and they were absolutely awesome; I could brake to a standstill from 20kmh on sheer ice in 3 bike lengths.
Did you make it yourself lamps. No What is the brand?
9 years ago on Step 3
Great :)
Nice scribe you you have . I'm going to bend and grind one out of a nice carbon steel scrap bar right now. What about using modified golf shoes steel nails, quite expensive but really nice stuff. Not so easy to find.
10 years ago on Introduction
where i am studded tires arent legal for cars so are studded tires legal for bikes everywhere?
are there any laws anywhere saying what you can and can't put on a bike?
11 years ago on Introduction
wast of bike tires but it is still awesome 4* sub
Reply 11 years ago on Introduction
Thank you, they are totally awesome as as you have the grip to ride in any conditions. This year they were used in anger for nearly three weeks and on compacted ice I could brake so hard the rear could endo, I have been asked to make sets for some of the guys at work but at the moment I am experimenting with different designs.
The tires I used were those cheap disposable ones that puncture or wear out so quickly that no one wants them so I gave them a much better life :)
like my tires theyr'e the wors i rearly ride on hard surfaces i ride ussually grass and theyr'e nealy have no grip
cool now i under stand maby i will try it
12 years ago on Introduction
This is wonderful - thanks. A really helpful thing to be able to leave in the shed for the winter months when the car won't make it but you are beginning to die of starvation, lack of exercise, or boredom. Thank you very much :) for a 5 star instructable!
Reply 12 years ago on Introduction
sorry - I did rate it five stars but it says 3.09 average from 1 rating !!??!!
You could also use the style of tube that is just a big foam ring. Forgive me, I don't know what it's actually called. No air involved but it's not a solid rubber tire either.
Sounds like an interesting idea, can you find a name for the tubes?
I looked into the solid tyres at http://greentyre.co.uk/bike.html after getting 4 glass punctures in 5 rides last year but haven't tried them yet.
Sorry so late a reply. I was just going through comments to my old post and found your question. I did a Google search and they seem to be called "Airless inner-tubes". I've seen them at Walmart. You are in the UK so I don't know if you have "Wally-World" there. It is a very firm almost solid inner-tube-like foam that goes inside of the tire (or as you say "tyre")
One could put little and thin nut on the threads to help prevent the screw head from puncturing the inner tube. I would not tighten them vary tight as to dent the treed but snug to prevent it from working in word making a puncture. Perhaps giving the spike more of a base could make a better bite on those rutted paths.
Dose look cool !
12 years ago on Step 3
very cool looking tyres, have you tried using shorter screws? the long screws may be tucking under/folding over as they hit the ice. I have alot of ice racing knowledge (Andros Trophy) and we spent days and weeks trying different stud lengths, regular findings where short was better on hard ice.
Does the length of the "studs" cause a problem. On car tires the metal studs only come out a little bit (maybe a quarter inch). I wonder if you would get less tire flex if the studs were only a quarter inch out of the tire, still giving you traction, but requriing less tire bending to still provide adequate contact. Nice instructable though.
Thank you.
The length is definitely excessive and no doubt increases the slippery feeling on normal ground. Using 1/4" shorter screws would probably be just as efficient but far more stable.
nice headlights
