Ichigo's Fractured Hollow Mask
Intro: Ichigo's Fractured Hollow Mask
STEP 1: Materials & Euipment
1) a mime mask (Like the one worn by Jaberwakeez on American Best Dance Crew)
2) a pair of yellow tinted sunglasses (I used a broken pair I had on hand)
3) Bondo Automotive body filler
4) Scissors
5) Exacto (craft) knife
6) Red, white, & black acrylic paint
7) Sand paper
8) Dremel (this is optional)
9) JB Weld
STEP 2:
STEP 3:
STEP 4:
Next you will be using the Bondo. Mix small amounts at a time as this hardens pretty fast if you are not used to using this material. Spread it over your mask to about a thickness of 1/8 inch. Don't worry if its rough you will be smoothing it out with the sand paper later. Make the thickness at the lower edge about 1/4 inch with a width of 1-1 1/2 inch. Let mask harden.
STEP 5:
STEP 6:
STEP 7:
Now paint the mask white. Use at least 3 coats,be careful not to get paint on the lens. and let dry. Carefully draw the striped patern on the mask and paint with red paint, again use 3 coats and avoid the lens, and let dry. Carefully paint a black border around the lens. one coat should do and let dry. I'v included a picture of my son using the mask at San Japan in San Antonio, TX.
20 Comments
dalessio1leo 12 years ago
Dadime 11 years ago
jbecklean 12 years ago
Dadime 12 years ago
Dadime 12 years ago
slayer500 12 years ago
Dadime 12 years ago
festologa 12 years ago
Can I use another putty instead of bondo?
Dadime 12 years ago
hg341 13 years ago
Dadime 12 years ago
shimmeringfae 13 years ago
Dadime 12 years ago
arrowcrest 13 years ago
Dadime 12 years ago
Timbhu 12 years ago
Dadime 12 years ago
jdamm 12 years ago
Dadime 12 years ago
