Introduction: Ikea Coffee Table Hack
Ikea Coffee table hack.
Material used Base cabinet cover panel and sultan LADE. All this item was pick up at the AS IT IS section, price is cheaper from buying a new table. This is good also for those like handy work.
Material List:
1) PERFEKT ROCKHAMMAR
Base cabinet cover panel.
2) SULTAN LADE (Single bed)
Slatted bed base, solid wood
Step 1: Cut the Sultan Lade wood into 2 pieces same length. You will require 2 full length is 70 cm. this will act as a table leg.
Step 2: Cut the Sultan Lade wood into 38 cm x 4 pieces. This will used as bracing support and support for leg.
Update Picture and info.
Step 3: Add supporting wood for table leg. view picture for detail. Measuring 35 centimeter for each bracing so total 4 pcs require.
Step 4: Added clear glass as table top, this is optional.
Hope this will be useful information to other that need simple coffee table. You may add Glass on top to give more better outlook.
Material List:
