Introduction: Illuminate Your Workspace
I had a single led to light up my entire keyboard for a while and it wasn't working out too well so I decided to go on a great oddesy into my garage and found a license plate light so i decided to use that instead of my led. READ ALL STEPS BEFORE PROCEEDING!!!
Step 1: Remove Previous Lights
remove whatever is in the way of where you are going to put you new light
Step 2: Gather Matirials
you need
-tape or other methods of mounting the light source
-scissors (if you are using tape)
-usb extension cable
-12 volt adapter (or other adapter that is the same voltage as the light source)
-light switch
-electrical tape
-phillips (star) screwdriver for the switch
-and of course a light source or 2
Step 3: Secure the Light Soures
secure the light source(s) and the switch using tape, screws or gum (i wouldn't recommend gum)
Step 4: Test the Lights
test the lights before and after you put them up
Step 5: Showing My Workspace
this is basically for the contest.
Step 6: Conclusion
after all that hard work (took me like an hour) you are finally done and now you can type in the dark
Share Your Space Challenge
3rd Epilog Challenge
