Introduction: Illuminated Clock Using a Scroll Saw
A very cool light up clock made by using a Scroll Saw.
Step 1: Materials/Tools
1 analog clock
1 large piece of plywood
Spray adhesive glue
Pencil
Scroll Saw or try the Dremel Trio
Styrofoam
Hot glue
Drill
Movable lamp
Spray adhesive glue
Pencil
Styrofoam
Hot glue
Drill
Movable lamp
Step 2: Trace
Trace the outside of the clock on thin plywood.
Step 3: Cut
Cut with a scroll saw the outside of the clock.
Step 4: Glue
Use spray adhesive glue ( do not put too much on because you want to be able to take this off after if you put too much on wait a bit for some of it to dray and attach to the round piece of wood).
Step 5: Drilling and Cutting
Drill a hole at the end of each number. Put the round saw in through each hole and cut it out.
Step 6: Attach to Light
Put it all together with the clock movment the clear plastic piece and the frame.
