Introduction: Impossible Corkscrew in a Liquor Bottle
This looks impossible. It is a corkscrew inside of a liquor bottle. It's actually easy to make and will make a great display piece, gift or addition to your man-cave.
Supplies -
- Empty liquor bottle. The shoulders should be wide enough to accommodate a corkscrew. The neck short enough that the corkscrew will reach the cork.
- A corkscrew with a wooden handle.
- Gaffer's tape
- A long thin stick.
- Epoxy
- Needle-Nose Pliers
Step 1: Procedure
- Remove the metal section from the wooden section.
- Loosen the hole a bit with a file
- Wrap the end of the corkscrew to a long dowel with gaffer tape or a similar tape
- Put a drop or two of quick-set epoxy in the end of the corkscrew handle
- Drop the corkscrew handle into the bottle
- Push the end of the corkscrew rod into the handle
- Let the epoxy set
- Draw the end of the corkscrew out
- Remove the gaffer tape
- Screw the corkscrew into the cork
- Replace the cork
