Introduction: Impossibly Easy Carnitas Tacos
Let's have a taco party!
I'm going to show you how to make pretty much fool-proof carnitas tacos. They're impossibly easy to make, and they're perfect for a casual party, an outdoor picnic, or even while you're out car camping. You'll be the hit of the party, and it's not even hard to do.
A note for purists: This isn't the definitive way to make carnitas tacos. In fact, it's kind of cheating because I use a crock pot instead of roasting a big piece of pork for many hours in the oven. It's also not as fatty as true, authentic carnitas, which traditionally uses lard. Yep, the hard stuff. I prefer doing it this way. It's no doubt much healthier.
One more thing: This recipe is perfect for a party in the park. I've set up a camp stove with a cast iron pan on top on a picnic table and cooked carnitas tacos to order for both kids' soccer parties and adult boozefests.
Wait... one more thing. I STRONGLY recommend using a cast iron pan for this. Otherwise, you won't get crispy carnitas.
What you'll need to make 15-20 modest-sized tacos
3 pounds of country style pork ribs, blade roast, or pork butt
1 jalapeno pepper
1 anaheim chili or other pepper of your choice (optional)
3-4 cloves of garlic
1 large white onion
1 bunch cilantro
4-5 limes or lemons (I happened to have lemons but prefer limes)
Salsa of your choice
A big pack of small corn tortillas
A large cast iron pan
Optional ingredients
Cumin, oregano, onion powder to season meat before cooking
Radishes for garnish
1 jalapeno pepper
1 large white onion
1 bunch cilantro
Step 1: Crack Open Your Crock Pot
First, get out your crock pot and toss your pork into it. Chop up your peppers, taking care to remove the seeds. Peel and roughly chop your garlic and toss it in the pot, too. If you have it, throw in 1/2 Tbsp each of cumin, oregano, and onion powder. The dry ingredients are optional, but if you have them I would recommend using them.
Turn your crock pot on low and cook for 8-10 hours. I usually cook the meat the day before I actually want to eat carnitas tacos and just put it in the fridge once it has cooled. You'll see that this is not a problem and may even be preferable.
Step 2: Prep, Shred, and Cook
When you're ready to cook your tacos, get yourself prepared so you can bang them out quickly. You want two things here: 1) a hot cast iron skillet that will retain heat and 2) partially shredded pork.
Carefully break up your pork. It will already be falling aprt from the crock pot cooking, but since it's been sitting in the fridge all night, you can still keep some large pieces intact. Don't shred your pork too finely because you want some chunks of meat. Mmmm. Meat.
Heat up your cast iron pan while you:
- Dice your white onion
- Chop up your cilantro
- Stack up some tortillas
Step 3: Plate and Try Not to Eat Too Many!
The great thing about cooking these in a big cast-iron pan is that you can push crisped up meat to one side and add more meat as you go — serving from one side of the pan while replenishing crock-pot pork from the other. Cast iron holds its heat, so you won't need to worry about adjusting the temperature. Just stick to medium after you get going.
It's important that you get some decent crispiness, so it's okay if the meat stays in the pan. It may dry out, but you will be adding salsa and citrus when serving, so don't worry too much about that.
To serve, heat two tortillas per taco and lay them on a plate on top of each other. Place some carnitas on the tortillas, sprinkle with white onions and cilantro, and slap a spoon of top-notch salsa on each taco. Garnish with quartered radishes and lime or lemon slices.
Repeat until everyone is happy.
