Introduction: Impowered Electrical Outlets
This instructable shows you how to hack an off-the-shelf power adapter to make an internet enabled power adapter using the Electric Imp. This lets you remotely control any mains powered device using a smartphone or web browser.
My garage "as-constructed" lighting is poor. You can use the available light for finding large objects like your car, but forget about that screw you just dropped. To fix the lighting problem I bought two 4 foot, 4 tube fluorescent shop lights to hang above my work area. Since the plug-point is in the ceiling roughly 12 feet high, I needed a way to remotely switch the lights on and off. I found a Stanley remote controlled power outlet at a local store and I was set, or so I thought. The first Stanley remote failed on day 1. The replacement unit failed after a couple of days. Third replacement unit failed a couple of months later. I never got around to taking it back to the store - I installed pull strings for the shop lights as an old-school temporary semi-remote solution.
What I needed was a WeMo or similar device. A perfect solution for my needs if maybe a little overkill. But, then it hit me. Most likely the failure point with the Stanley device is the RF circuit that controls the switching of the AC. If I replaced that circuit with an Electric Imp, I wouldn't need to mess with the AC circuit design which is already UL approved for safety, and would have a nicely made enclosure to boot.
I grabbed a Philips screwdriver and opened the Stanley unit up. The insides appeared to be PERFECT for an Electric Imp(http://www.electricimp.com) retrofit with minimal effort... or so I thought. My shop lights were headed into the internet cloud. Unfortunately the plan to replace the RF circuit with an Electric Imp hit a major roadbump because the the DC power supply on the Stanley power strip cannot deliver enough current to power the Electric Imp. The Imp requires about 400mA on WiFi transmit, so the hack turned out to be more invasive than I had intended, involving an Imp, cellphone charger and relay board, shoehorned into the Stanley enclosure.
Since the Holiday season is right around the corner, this will allow you to control your light display from wherever you and your Smartphone happen to be, even if it is just from the couch to avoid the nightly trip into your snow filled yard.... just keep waterproofing in mind if you do this so that you don't unintentionally create an electrical hazard.
The Stanley unit I used is still available from various internet sites so if you want a basic WeMo'ish like device, with complete access to the source code and electronics that you can hack to perfection, this Instructable will get you there.
Step 1: How It Works
The Imp firmware receives the message from the cloud based Agent and sets the relay output accordingly. This allows you to turn the Stanley outlets off or on by pressing the button on your SmartPhone or web browser with minimal software and firmware development effort. Nice!
Step 2: The Stuff You'll Need
Parts
- Stanley Remote Powered Outlet. The unit I used is still available for about $16 from 1000Bulbs.com I like the convenience of having 3 outlets
- Electric Imp https://www.sparkfun.com/products/11395
- Electric Imp carrier board https://www.sparkfun.com/products/11400
- SainSmart 2-Channel Relay Board. Has opto-isolator inputs. I bought this board for another project. At that time (August 2013) it was under $5 delivered with Amazon Prime. The current price is $9 http://amzn.com/B0057OC6D8
- 1 x 4 Pin Molex connector. I bought mine from Jameco.com
- 1 x 3 Pin Molex Connector. Jameco.com
- 5 x Connector contacts for Molex KK Series connectors. Jameco.com
- Thermistor - 10K https://www.sparkfun.com/products/250 (Optional - I still need to write the code for this)
- iPhone USB Charger for powering the imp - Amazon has the best prices
- USB Cable that will be mutilated to supply power to the Imp. If you get one with a small plug end (like the one that comes with the iPhone, you will be able to avoid the connector mutilation step!)
- Philips screw driver for disassembling the Stanley unit. Needless to say your warranty is void as soon as you do this
- Soldering Iron and solder- Radioshack has a variety
- 24 or 26 or 28 Gauge hookup wire for connecting the electric imp I/O to the relay. Radioshack has different colors of 24 gauge available http://www.radioshack.com/product/index.jsp?productId=21982396, http://www.radioshack.com/product/index.jsp?productId=21982416&locale=en_US
- Sharp utility knife
- Small electrical tools (wire cutter, wire stripper etc)
- Small drill bits (1/16") and drill for making the Imp Slot in the side of the Stanley unit. Alternately a Dremel tool with appropriate cutting bit.
- Hot Glue Gun and Glue Sticks for mounting the Electric Imp and the Relay within the housing. I used the high-strength type..
Remember, as soon as you open the Stanley Remote AC Outlet switch, your warranty is void. Also, make sure you work with appropriate safety procedures for main powered devices. Unplug the Stanley unit before working on it. While it is unplugged, you can work on it safely without fear of accidentally shocking yourself. If you attempt to work on the unit while it is plugged in, the live voltages (115VAC) inside the Stanley unit are enough to kill you. Never work on the internals of the Stanley unit when the cover is removed and the unit is plugged in. Be safe.
For tools use standard DIY safety procedures and always wear safety glasses.
Step 3: Disassembly and Modification
Remove the remote control PCB and dispose of it. We won't be using it again. This is where the Imp will be installed.
There are 2 large plastic bosses molded on the lower plastic housing that the original RF board was mounted to. These bosses can be cut off with a pair of side cutters and be smoothed down further with a dremel tool. The Imp and relay circuit boards will be glued to the base. Removing the bosses is needed so that the relay board will mount low enough to clear the top cover when the Stanley unit is reassembled.
Remove the main circuit board from the shell. Using a Dremel tool with a cut-off disk, carefully cut around the existing circuit so that you leave only the AC part of the circuit board as shown in the pictures. Cutting the PCB is necessary to provide clearance for the new relays that will switch the outlets on and off. You want to leave the main AC tracks that support the power outlets.
To provide a slot for the electric imp card, a slot needs to be made in the side of the housing. Initially I had intended to use the Stanley unit built in regulator to power the imp. When this proved to be inadequate power, I had to relocate the slot to the opposite side of the lower housing. To make the slot, drill a number of 1/16" holes in roughly a straight line, and then use a small file to square up the slot. Don't make your slot where these pictures show..... look at the final pictures in the last step to see where the slot should go!
Step 4: Electrical Detail and Assembly
Please make sure the Stanley unit is not plugged in before you start work on it.
The relay board I used has two 10A relays that will switch with a 5V coil voltage. In order to ensure a 15A rating of the hacked unit, I used the relays in parallel to provide a load rating of 20A. This provides a decent safety factor for a power adapter connected to a standard 15A breaker protected home wiring circuit. If you use a higher current relay, you could switch the power outlets individually. If the power strip is rated at 15A, then any of the outlets must be safe to operate to 15A. By wiring the relays specified for this instructable in parallel, you can ensure that any single outlet or all 3 outlets together can draw 15A safely. More load than this and the circuit breaker in your home wiring panel will trip to protect the circuit.
The power for the electronics is supplied by a iPhone USB charger. I had a spare that I could use. They are inexpensive and available on Amazon and ebay. It is cheaper to buy the charger which comes with a USB cable than to buy the components to build your own power supply. The iPhone form factor works well in the limited interior space of the Stanley unit. Use spade terminals to connect directly to the AC terminals of the charger. Use heatshrink to cover the exposed parts of the AC terminals to prevent accidental contact. The USB cable I found in my project box had a bulky molded connector. Using a sharp knife, the plastic moldings were removed. The red and black wires of the USB cable where replaced with 26 gauge wire to provide more mechanical robustness and then the connector was further protected using heatshrink as seen in the pictures.
Originally, I had intended to switch the relays independently so that I could control at least 2 outlets independently. That is how the circuit was originally wired up. After investigating the current carrying capacity of the relays, I chose to parallel the relay outputs. The connection between the Imp and the Relay board has two Imp pins controlling each relay. In reality, you can just connect one Imp pin to both relay inputs. The firmware switches both pins together so either way is fine.
The AC Neutral and the AC Ground is already connected to the electrical outlet sockets. Leave everything connected the way it comes from the factory. The only wire that needs to be modified is the AC Live wire (Black Wire). This wire needs to be t'd or branched so that you have a live wire entry to each relay as shown on the schematic. Protect the join with heatshrink. I used a small piece of 16AWG wire for this branching. 16AWG multistrand wire can typically carry 22Amps when used for short haul chassis wiring.
The relay outputs are soldered to the underside of the AC PCB as shown in the picture. When all the connections are made, squeeze everything into the housing as shown and hot-glue the relay and imp boards to the housing base.
Step 5: Imp Firmware,Agent Code and Blink-up
Once the BlinkUp is complete, your imp will appear on your IDE under New Devices. If you have not used an Electric Imp before, I suggest you first try the Hello World example on the Electric Imp site to get the hang of the Imp. There is also a great guide to the imp on instructables written by @beardedinventor: https://www.instructables.com/id/Getting-Started-with-Electric-Imp/
The firmware for the imp is attached to this step as ImpoweredImp.nut
The code for the agent is attached as ImpoweredAgent.nut
Firmware and Agent code interaction
Your Agent has a URL specific to it. When an HTTP message is sent to this URL, your Agent code running in the Imp Cloud checks the validity of the request by comparing the incoming API Key (any key you make up - more bits make it harder to guess) with the API Key stored in memory of the Agent (API Key idea from http://forums.electricimp.com/discussion/comment/8281#Comment_8281). If the Key's match, the message is checked to determine if a buttonPress event or Status request is being passed in the HTTP Request packet.
If the HTTP Request is for status, the Agent code returns the On/Off status of the AC outlets. The status is asynchronously updated by the Imp firmware when the output pins change state.
If a buttonPress event is passed in the HTTP Request, this event is passed to the Imp firmware over the electric imp secure communication channel between the Imp and the server based Agent. The Imp "receives" this event through the agent.on("buttonPressed", function( value ) function. Every time a button press event is received by the Imp, the output state of Pin1 and 7 is toggled which turns the relays On or Off depending on the previous state. The status variable is sent back to the agent via the Agent-Imp communication channel and is received by the Agent in the device.on function.
Step 6: IPhone HTML/Javascript Code
Communicating with the Electric Imp is done by sending a message to the URL of the Agent which is specific to your particular Imp. In the HTML App, we create an XMLHttpRequest object and then post the button press event in a formatted JSON packet to the agent URL.
xmlhttp.open("POST", "https://agent.electricimp.com/YourURL?timestamp=" + new Date().getTime(), true);
xmlhttp.setRequestHeader("Content-type", "application/x-www-form-urlencoded");
xmlhttp.setRequestHeader("x-apikey", "Your API Key");
var impRequest = { "request": "buttonPressed", "button" : button.id };
xmlhttp.send(JSON.stringify(impRequest));
To get status of the power outlets, the Agent is queried
var impRequest = { "request": "GetStatus" };
xmlhttp.send( JSON.stringify( impRequest ));
To make the HTML page appear as a native App on your iPhone, you need to load it from a web site, and then add it to your home screen. The process is described in my previous instructable here: https://www.instructables.com/id/Electric-Imp-Garage-Door-Opener/step10/Configuring-IIS-Express-And-Loading-The-App-onto-y/
The iPhone files are attached to this step
Step 7: It Works!
- Remote control of your in-house devices like lamps, hi-fi, TV etc. You can enhance the software and build multiple devices to allow you to control the lighting of your home to make people think that the house is occupied while you are away. You can turn your TV on and off to add to the illusion. You could enhance the firmware and smartphone software to program each device to run on a different on/off schedule to simulate the random nature of real people within your home to complete the illusion for security purposes when you are away.
- You can add remote control for difficult to access power points.... my garage lights for example!
- You can see the status of your outlets to answer the questions that always seem to come up after you are already many miles into a trip away from home like "honey did you turn the iron, hair hot stick, fish tank filter, pool filter, light timers" on / off depending on the nature of each device.
- Add motion sensor to automatically turn things on/off when motion is detected.
- Add a Thermistor or other temperature sensing device to monitor the room temperature.
- Figure out how to connect to IFTTT.com so that you can, for example, email, FB Message, Tweet your outlet to turn on /off
- Please comment below and I'll add your ideas to this list!
If you build one, please add to the comments and let me know of any additional features you added or alternative power outlet devices you hacked to achieve the same end. Also, if you figure out how to IFTTT this thing, I like to know how too!
Cheers!
