Improve Knight Rider Circuit
Intro: Improve Knight Rider Circuit
Change by: https://www.instructables.com/Knight-Rider-Circuit/
It's just a simple circuit that uses Arduino to make nine LEDs light up in different ways.
STEP 1: Set Up the Circuit and the Button
Different from the circuit that I change, it will need 3 buttons to make it have more pattern.
STEP 2: Programing
int pin2 = 2; int pin3 = 3; int pin4 = 4; int pin5 = 5; int pin6 = 6; int pin7 = 7; int pin8 = 8; int pin9 = 9; int pin10 = 10; int timer = 50;//改1:間隔時間從40改成50的; void setup() { pinMode(pin2, OUTPUT); pinMode(pin3, OUTPUT); pinMode(pin4, OUTPUT); pinMode(pin5, OUTPUT); pinMode(pin6, OUTPUT); pinMode(pin7, OUTPUT); pinMode(pin8, OUTPUT); pinMode(pin9, OUTPUT); pinMode(pin10, OUTPUT); pinMode(11, INPUT); } void loop() { digitalWrite(pin2, HIGH); delay(timer); digitalWrite(pin2, LOW); delay(timer); digitalWrite(pin3, HIGH); delay(timer); digitalWrite(pin3, LOW); delay(timer); digitalWrite(pin4, HIGH); delay(timer); digitalWrite(pin4, LOW); delay(timer); digitalWrite(pin5, HIGH); delay(timer); digitalWrite(pin5, LOW); delay(timer); digitalWrite(pin6, HIGH); delay(timer); digitalWrite(pin6, LOW); delay(timer); digitalWrite(pin7, HIGH); delay(timer); digitalWrite(pin7, LOW); delay(timer); digitalWrite(pin8, HIGH); delay(timer); digitalWrite(pin8, LOW); delay(timer); digitalWrite(pin9, HIGH); delay(timer); digitalWrite(pin9, LOW); delay(timer); digitalWrite(pin10, HIGH); delay(timer); digitalWrite(pin10, LOW); delay(timer); digitalWrite(pin10, HIGH); delay(timer); digitalWrite(pin10, LOW); delay(timer); digitalWrite(pin9, HIGH); delay(timer); digitalWrite(pin9, LOW); delay(timer); digitalWrite(pin8, HIGH); delay(timer); digitalWrite(pin8, LOW); delay(timer); digitalWrite(pin7, HIGH); delay(timer); digitalWrite(pin7, LOW); delay(timer); digitalWrite(pin6, HIGH); delay(timer); digitalWrite(pin6, LOW); delay(timer); digitalWrite(pin5, HIGH); delay(timer); digitalWrite(pin5, LOW); delay(timer); digitalWrite(pin4, HIGH); delay(timer); digitalWrite(pin4, LOW); delay(timer); digitalWrite(pin3, HIGH); delay(timer); digitalWrite(pin3, LOW); delay(timer); if (digitalRead ( 11 )) { digitalWrite(pin2, HIGH); //改2:我增加了三個按鈕,每個if下面的動作都是自行增加的, digitalWrite(pin10, HIGH); delay(timer); digitalWrite(pin2, LOW); digitalWrite(pin10, LOW); delay(timer); digitalWrite(pin3, HIGH); digitalWrite(pin9, HIGH); delay(timer); digitalWrite(pin3, LOW); delay(timer); digitalWrite(pin9, LOW); delay(timer); digitalWrite(pin4, HIGH); digitalWrite(pin8, HIGH); delay(timer); digitalWrite(pin4, LOW); digitalWrite(pin8, LOW); delay(timer); digitalWrite(pin5, HIGH); digitalWrite(pin7, HIGH); delay(timer); digitalWrite(pin5, LOW); digitalWrite(pin7, LOW); delay(timer); digitalWrite(pin6, HIGH); delay(timer); digitalWrite(pin6, LOW); delay(timer); } if (digitalRead ( 12 )){ for (int i = 0 ; i < 2 ; ++i ){ digitalWrite (pin2, HIGH); digitalWrite (pin3, HIGH); digitalWrite (pin4, HIGH); digitalWrite (pin5, HIGH); digitalWrite (pin6, HIGH); delay(timer); digitalWrite (pin2, LOW); digitalWrite (pin3, LOW); digitalWrite (pin4, LOW); digitalWrite (pin5, LOW); digitalWrite (pin6, LOW); delay(timer); digitalWrite (pin6, HIGH); digitalWrite (pin7, HIGH); digitalWrite (pin8, HIGH); digitalWrite (pin9, HIGH); digitalWrite (pin10, HIGH); delay(timer); digitalWrite (pin6, LOW); digitalWrite (pin7, LOW); digitalWrite (pin8, LOW); digitalWrite (pin9, LOW); digitalWrite (pin10, LOW); delay(timer); } } if (digitalRead ( 13 )) { digitalWrite (pin6, HIGH); delay(timer); digitalWrite (pin6, LOW); delay(timer); digitalWrite (pin5, HIGH); digitalWrite (pin7, HIGH); delay(timer); digitalWrite (pin5, LOW); digitalWrite (pin7, LOW); delay(timer); digitalWrite (pin4, HIGH); digitalWrite (pin8, HIGH); delay(timer); digitalWrite (pin4, LOW); digitalWrite (pin8, LOW); delay(timer); digitalWrite (pin3, HIGH); digitalWrite (pin9, HIGH); delay(timer); digitalWrite (pin3, LOW); digitalWrite (pin9, LOW); delay(timer); digitalWrite (pin2, HIGH); digitalWrite (pin10, HIGH); delay(timer); digitalWrite (pin2, LOW); digitalWrite (pin10, LOW); delay(timer); } }<br>
Download the code, and you can change the time of the interval or the order of the LEDs.
