Introduction: Improved Hood Light LED Mod
This instructable will show you how to modify me Hood Light LED Mod so you get more light.
Step 1: Step 1: What You Need
You will need:
Wire
LED reading light
Modified hood light
Tools:
Soldering iron and solder
Hot glue gun and glue
Wire strippers and cutters
Screwdriver
Wire
LED reading light
Modified hood light
Tools:
Screwdriver
Step 2: Step 2: Start
Start by taking apart the LED reading light and desolder the wires.
Step 3: Step 3: Cut
Now cut the circuit in half.
Step 4: Step 4: Solder
Now solder wires to each LED board. Then solder them together in parallel
Step 5: Step 5: Dissasemble
Now open up the modified LED hood light, desolder the LEDs from the wire and the resistor. Then solder the LEDs to the wire and the resistor.
Step 6: Step 6: Glue Pt. 1
Now cover any exposed wire with glue, but NOT the resistor.
Step 7: Step 7: Glue Pt. 2
Now tuck all the wires into the base, glue the LED circuits into place and hold fr 2 minutes. Then clean any glue strands.
Step 8: Step 8: Done
Now put the cover back on the assembly, and test it out!
Step 9: Final Note
Thank you for viewing my instructable. Please leave any comments, questions or suggestions, and please rate my instructable. Thanks!
