Improvised Pyrotechnic/Firework Fuse.
Intro: Improvised Pyrotechnic/Firework Fuse.
Small and simple improvised firework pyrotechnic fuse for say adding a delay to to a firework or just because.
1.Very simple to make visco type/style fuse take 3/6 boxes full of matchs and grid off the matchheads,crush or mill into a fine powder i use a coffee mill since it perfect size for crushing them.
2.Collect a bunch of absorbent string not rope,shoelace will do just make sure to soak it in water before your try to apply anything to it will stick much better to the string.
3.Obtain a small and disposable bowl of some kind for mixing the match head dust into a watery plaster like consistency and use the back of a small spoon ,or your hands but would not advise it will stain your skin and probably damage you in some fashion,You can use a rubber glove but it will be tricky but far safer for you try find a thin pair that will not impair your movement.
Apply using blobs or just coat the back of the spoon and press into the string,over the bowel,paper etc so any spillage is not lost .Carry on till you have a nice coating on all the wire/fuse etc and let it dry overnight.
4.Keep this stuff in an airtight containers and will keep for a long usable time.
5 Comments
Noram27 10 years ago
I can suggest soaking the string in saturated KNO3 solution instead of plain water. It works very nicely. Adding some glue to the mixture on the outside of the string really helps it stick, too.
Lectric Wizard 10 years ago
u971 10 years ago
u971 10 years ago
https://www.instructables.com/id/How-to-make-small-Grenadesfor-airsoftpyro/
