Introduction: Impulse III Metal Detector Short Review
A miniature inexpensive module that by adding a battery and a coil you can turn it into a Metal Detector with excellent features.
- Impulse 3 Metal Detector Module
- Search Coil
- Speaker: 0.25W, 8 ohms
- Battery
Step 1: Description
Recently, quality metal detector modules have appeared on the market for a very low price. Almost no knowledge of electronics is required to make the final product. This time I will present you one such module and I will try to briefly capture its features.
The module is sold under the name "Impulse III", and its price on Ebay is about 35 dollars. It arrived nicely packed, and protected from mechanical damage, very quickly in about 15 days from Kazakhstan to Macedonia. The device is compact and solidly built and the main panel is only slightly larger than the LCD screen. On the front there are two large buttons through which we perform all the necessary settings.
Step 2: Coil
The coil is identical to the one I use in my DIY Pulse Induction Metal Detectors, and This coil dimension represents a kind of compromise in relation to coils specialized for detecting small objects (which are mostly of smaller diameter), and those made for detecting larger massive objects at a greater distance (in these the diameter can be 1m or more ).
If you want to make a PCB for this project, or for any other electronic project, PCBway is a great choice for you. PCBway is one of the most experienced PCB manufacturing company in China in field of PCB prototype and fabrication. They have a large online community where you can find a Open Source projects, and you can also share your project there. From my personal experience I can tell you that on this community you can find many useful projects
Step 3: Setting
The detector worked immediately after switching on, but only required some adjustment. It is necessary to press "B" button after switching on, as well as in case of signal drift, increased noise and false positives. To enter the settings menu, you need to hold down the "A" button for a few seconds. Further, the buttons "A" and "B" are used to select a category, after which it is necessary to hold down the button "A" for several seconds. Now you can change the parameters of the current menu item. To exit the current menu item, hold down the "B" button for a few seconds. To return to the main (working) screen, you need to hold down the "B" button again for a few seconds.
Step 4: Conclusion, Connecting Diagram
As in the previous review for the Clone Pi-W Metal Detector, I am really pleasantly surprised by the features such as sensitivity and stability in operation, considering that it is a very inexpensive module, and to make a complete mid-range metal detector we need almost no knowledge from the field of electronics. This time I would like to emphasize that the results were a little better, but in real conditions, in moderately wet soil, many false alarms occur, so to avoid that, filters are used that also slightly reduce the sensitivity. Thus, the final result when comparing these two metal detectors is almost identical.
All we have to do is solder a few wires, and the only thing is to be very careful about the polarity of the battery.
