Introduction: Indoor Floral or Fruity Wall
I suggest you create a wall chart with recovery items
What you will need ?
- Recovery pot (plastic bottle, tin can, glass pot etc...)
- Fabric
- Iron wire or rope
- Soil with compost or other natural boost for plant
- Fork
- Washi tape
- peint brush
- Plant of your choice
- Wood glue and Water
- Pliers
- Diaper (what ? yes, diaper...unused diaper)
- All necessary to hanging pots on the wall
Step 1: Planter's Embellishment
We'll cover fabric pots
- Measure the height and circumference dimensions of your container
- Cut the fabric according to your measurements
- Mix the glue with water (half / half)
- Glue the back of the fabric
- Cover the container with fabric
- Put glue a second time
- Let dry
Step 2: Creating Ties
- If you have glass jars, create a clip with wire.
- Go around the pot with the wire,
- you kink the 2 ends at the base and along then you make a loop (see photo)
- If you have iron or plastic boxes, create a tie with string.
- make 2 holes,
- pass an end of the rope in each hole
- tie a knot at each end to hold the rope
Step 3: Fork Hook
- Take a tweezers to tweak the fork's teeth : Use your imagination
- Take a big pliers to twist the body, you have to bend and after half
- To hang the fork you can:
- Put the screw between two teeth (like i do) or, drill a hole,
- Drill the wall and fix the forks
Step 4: Seed Plants
You will need:
- Plants of your choice
- brown cardboard
- soil with compost
- Diaper
- Prepare the media :
- Retrieve the absorbent gel on the diaper
- Mix with potting soil
- Soak the plant in water at room temperature to break the clod
- Put brown cardboard at the bottom pot (it used to absorb some excess water and feed the plant)
- Cover with soil layer put the plant and fill with potting soil
- According to the plant and the pot, there may be no soil to add, in this case just put the gel
The gel layer serves to absorb and retain water : this will prevent you from drowning the plant and in addition you will have less need to water
Step 5: Decorate
- Hang the pot on the wall
- Put washi tape around the pot on the wall to do like a tableau
Et voilà ! You make it ! Enjoy !
You can use :
- Strawberry for a fruity wall
- Flowers for a colored wall
- Seasonings for a perfumed wall
