Introduction: Inductance LC Meter Using Arduino
In this project, we will display Inductance as well as capacitance along with frequency on 16X2 LCD.
Hardware Components
Arduino Uno
741 OPAMP IC
3V battery
1n4007 diode
Resistor 100ohm, 10k
Potentiometer 10k ohm
Pushbutton switch
Inductor
Capacitor
Connecting wires
Software Components
Arduino IDE
Step 1: About Project
First, we estimate the frequency by utilizing Arduino and by using a few mathematical calculations we can determine the inductance or capacitance.
We are going to use an LC circuit frequency response formula.
f=1/(2*time) where time is output of pulseIn() function
then we have LC circuit Frequency:
f=1/2*Pi* (square root of LC)
by solving the above equations we get inductance as follows
L=1/(4* pi* pi* f* f* c)
We have a frequency that can be turned into inductance by utilizing the above formula. We have used Arduino for further operation. The LC circuit contains an inductor and a capacitor. We have used an operational amplifier ( 741 ) to convert sinusoidal resonance frequency to a digital or square wave.
We have used a 3v battery connected in reverse polarity to get the correct output frequency. Another we have used the push button to change the operation mode (either we are measuring inductance or capacitance). LCD is used for display purposes.
IoT Training will help you to know more about IoT Devices.
Step 2: Run a Program
#include
LiquidCrystal lcd(A5, A4, A3, A2, A1, A0);
#define serial
#define charge 3 #define freqIn 2 #define mode 10
#define Delay 15
double frequency, capacitance, inductance;
typedef struct { int flag: 1; }Flag;
Flag Bit;
void setup() { #ifdef serial Serial.begin(9600); #endif lcd.begin(16, 2); pinMode(freqIn, INPUT); pinMode(charge, OUTPUT); pinMode(mode, INPUT_PULLUP); lcd.print(" LC Meter Using "); lcd.setCursor(0, 1); lcd.print(" Arduino "); delay(2000); lcd.clear(); lcd.print("Circuit Digest"); delay(2000); }
void loop() { for(int i=0;i 0.1) frequency+= 1.E6 / (2 * Pulse); delay(20); } frequency/=Delay; #ifdef serial Serial.print("frequency:"); Serial.print( frequency ); Serial.print(" Hz "); #endif
lcd.setCursor(0, 0); lcd.print("freq:"); lcd.print( frequency ); lcd.print(" Hz ");
if (Bit.flag) { inductance = 1.E-3; capacitance = ((1. / (inductance * frequency * frequency * 4.*3.14159 * 3.14159)) * 1.E9); if((int)capacitance < 0) capacitance=0; #ifdef serial Serial.print("Capacitance:"); Serial.print( capacitance,6); Serial.println(" uF "); #endif lcd.setCursor(0, 1); lcd.print("Cap: "); if(capacitance > 47) { lcd.print( (capacitance/1000)); lcd.print(" uF "); } else { lcd.print(capacitance); lcd.print(" nF "); } } else { capacitance = 0.1E-6; inductance = (1. / (capacitance * frequency * frequency * 4.*3.14159 * 3.14159)) * 1.E6; #ifdef serial Serial.print("Ind:"); if(inductance>=1000) { Serial.print( inductance/1000 ); Serial.println(" mH"); } else { Serial.print( inductance ); Serial.println(" uH"); } #endif
lcd.setCursor(0, 1); lcd.print("Ind:"); if(inductance>=1000) { lcd.print( inductance/1000 ); lcd.print(" mH "); } else { lcd.print( inductance ); lcd.print(" uH "); } }
if (digitalRead(mode) == LOW) { Bit.flag = !Bit.flag; delay(1000); while (digitalRead(mode) == LOW); } delay(50); }
