Introduction: Industrial Bedside Lamp
I love working with wood and metal and I love lamps. What better way to combine both than building an industrial style bedside lamp from wood, a pipe and a wrench?
Resources:
a light bulb
a light bulb socket
a switch
a plug
a big wrench
a short malleable iron pipe with an end cap
a piece of wood (I used oak)
two pieces of sheet steel
an electric motor (not necessary)
screws
Tools:
a router
a drill
sandpaper
a saw for wood (jigsaw / table saw ...)
something to cut metal (tin snips / jigsaw / angle grinder ..)
a 3d printer
Step 1: Preparing the Wood
At first I used my jigsaw to cut the wood to size. After a little cleanup with sandpaper, I turned the board over and hollowed it out with my router, making place for the switch and the cables. Next I drilled a big hole for the pipe to screw in. It doesn't have to be perfect, as everything is going to be covered up later on.
Step 2: Attaching the Wrench to the Pipe
For attaching the wrench to the pipe, I used my 3d printer to print out a little piece, that can be glued to the outside of the pipe, that the ring of the wrench fits onto.
But before glueing it all together, I drilled a hole into the pipe and also in the middle of the wrench for the cable to go through.
After that was done, with some 5-minute-epoxy all the parts can be glued together. The plastic part is held to the pipe with zip ties. To cover up some of the plastic, I glued the front side of the same motor to the ring of the wrench.
Lastly, the end cap can be screwed to the upper thread of the pipe.
Step 3: Wiring and Assembly
First, I passed the cable through the pipe, out of the little hole I drilled, through the hole in the wrench and over its jaw. On the end I attached the lamp socket and fixed the cable in place with some copper wire from the electric motor . Then it was time to screw the pipe into the wood. It's starting to look like a lamp!
For esthatics, I again took a part of the electric motor and attached it to the switch with a screw and some glue. I then cut a piece of the sheet steel and drilled a few holes in it. Four small ones on the cornes for screws and a big one on the inside for the switch. I decided to spray paint it black, but that it would also have looked great if i left it sanded. With some more epoxy, the switch can now be glued to the steel.
With four small screws I attached my beautiful switch to the wood and wired everything up. As I'm not an electrician, I'm not going to tell you how I did that.
Because leaving all the wires exposed isn't that great, I used another piece of sheet steel to cover it all up and screw to the bottom of the wood.
DONE!!!
