Introduction: Industrial Hand Rail
Check out this quick and easy tutorial on making an Industrial Hand Rail.
Materials Needed.
2" Square Tubing
1" round tubing
Acetone
Matte Clear Coat Enamel
Tools Needed
Angle Grinder
Metal Cutting Saw ( I use EVOLUTION RAGE 3)
Welder ( Lincoln MIG 210MP)
Grinding Wheels
Wire Wheel
Safety Wear
Welding Helmet (Lincoln Viking)
Welding Gloves
Welding Jacket
Safety Glasses
Respirator
Neoprene Gloves
Step 1: Cut Your Parts to Size
Grab your favorite cutting tool. Whether it is the good ole abrasive disc on the grinder, chop saw, bandsaw or a mitre saw with a carbide wheel like mine here from Evolution Power Tools
Step 2: Mock Up Your Layout for External Frame
Mock up the outside framing and chamfer the ends to give the weld some room to penetrate the metal.
Step 3: Tack Tack Tack
Tack weld your framing together. After your frame is tacked, go ahead and layout your interior bars. Using a spacer and clamps to make sure it is uniform. First tack into place, then finish weld.
Step 4: Finish Weld
Finish weld all your tacks working your way around your project.
Step 5: Grind and Prep
Grind this SOB to a smooth surface, then wipe down with Acetone. I finish with Clear Coat matte enamel.
To Mount the rail, drill through the bottom framing and secure to flooring with lag screws leaving the heads exposed. Then attach to wall doing the same.
