Introduction: Industrial Wall Sconce Repurposed Sewing Machine Edison Lamp
I’ve been putting together a few pieces of decorative furniture recently. Treadle sewing machines have caught my eye. I’ve been trying to use the every part of these wonderful machines. With the addition of this lamp I have made as many as 4 pieces of furniture from one treadle sewing machine.
Step 1: Carefully Remove the Sewing Machine.
First find an old (broken beyond repair) treadle sewing machine. Then carefully remove the sewing machine from the cabinet.
Step 2: Remove Any Superfluous Hardware
Once you've removed the sewing machine remove any superfluous hardware that may be in the way or could cause a safety hazard. You can see here that I chose to remove the old hinges. (I kept them for another project of course).
Step 3: Pathways for the Electrical
Inspect all of the potential pathways for the electrical. One of the more difficult parts of this lamp will be safely navigating the lamp cord through the sewing machine. It needs to be done so the cord will not be severed by the internal mechanisms. That way it's safe for anyone to spin the wheel on the sewing machine.
Step 4: Remove the Front Cover
Remove the front cover and take a look at what has to be removed. This front compartment has to have room for the lamp cord and the bulb housing. Save the front cover because you'll need to modify it soon.
Step 5: Remove the Unnecessary Mechanisms
I use a Dremel tool to cut and remove the unnecessary mechanisms. Try to make space for the new lamp parts while trying to keep as many of the original parts. Any parts that show on the outside of the sewing machine will need to stay.
Step 6: Remove More
The circular disc portion in the center will vary from machine to machine. It's attached to a shaft that connects the treadle to the sewing machine's wheel. The entire disc and shaft must be removed.
On this particular machine I had to hand cut the shaft with a make-shift hacksaw. The trick is to hold a reciprocating saw blade with Vise Grips. I show to to do this in the video.
Step 7:
Here's what it looks like with the disc removed.
Step 8: Time to Modify the Face Plate
This hole saw was a little too small for the light bulb housing diameter.
I finished sizing the opening with a die grinder. A Dremel tool would work too. Go until the light bulb housing fits.
Clean and sand the sewing machine face. I chose to paint it black but a brushed finish would look good too.
Step 9: Prepare the Lamp Cord
Dismantle the lamp cord so it can be fished through the sewing machine.
Step 10: Fish the Lamp Cord Through the Sewing Machine
Here's an image of the cord after I fished it through the machine.
Step 11: Cover Plate Install
Reconnect the light bulb housing to the cord and install the modified front cover plate.
Step 12: Feet and Hook Install
Install rubber feet and a hanger if you would like to use your lamp a wall sconce.
Step 13: View As a Wall Sconce
Enjoy your new sewing machine lamp!
Step 14: As a Desk Lamp.
It can be used as a desk lamp too.
Thank you for reading my instructions!
