Introduction: Infinit E Battery
Able to power 12 volt power regulators and recharge nine volt batteries
Step 1: Infinit E Battery
you will need 5 rechargeable batteries, one 3 volt non latching DPDT relay, and two small 12 to 18 volt generators, one 12 volt solar panel, 0ne voltage tripler circuit
Step 2: Infinit E Battery Solar Charging
STEP 2 connect batteries in parallel to relay.
STEP 3 connect solar panel to relay switch and outer pins.
STEP 4 connect nine volt motor to pin 1 and 2 of DPDT.
STEP 5 both solar panel and batteries can make motor turn.
STEP 6 only one generator will need voltage tripler circuit to recharge batteries as the motor turns.
STEP 7 the other generator will supply 12 volts of power to power inverter
